R52 Crush washers on the transmission fill/drain plugs?
Old Jul 17, 2020 | 10:40 AM
Sean Morrison's Avatar
Sean Morrison
Hi, I'm new to the R52 and noticed while replacing the transmission oil that there were no crush washers. Is that normal?
I've already changed the transmission oil (after much reading, went with RedLine D6 ATF instead of MTL), tightened to 32 ft/lbs without crush washers (a bit higher than to spec because I didn't trust it), and there's no sign of leaking. Should I plan to add crush washers? I couldn't find a part diagram to determine if washers are typical on this transmission.
Cheers!
Sean
Old Jul 19, 2020 | 09:02 AM
Mineeee's Avatar
Mineeee
I dont recall a crush washer when I did my gearbox fluid. Could be because BMW considered it a lifetime fluid so didnt plan on it getting changed? I'm using Royal Purple Synchromax in my Justa, which seems to be fine, its a lot cheaper than the BMW fluid. Engine Oil plug does use a crush washer.
Old Jul 23, 2020 | 01:49 PM
nd-photo.nl's Avatar
nd-photo.nl
You can find parts diagrams here: https://mini.7zap.com/en/mini/r53/cooper+s/
Crush washers are only used on banjo bolts afaik (turbo oil line, turbo coolant line, brake lines, etc)
k2at11
Aug 12, 2013 03:13 PM
Zac Spivey
Classic Mini Talk
Oct 2, 2012 01:47 PM
GregO
Nov 24, 2008 09:22 AM
javelina1
Jan 22, 2007 02:32 PM
donniebronx
Aug 4, 2006 03:26 PM
