R52 Shake, rattle and roll
Old Dec 2, 2008 | 11:52 AM
  #26
Moltenmini's Avatar
Moltenmini
Originally Posted by jdamann
WOW...would be a shame if we had to go down that path but...that is what it's there for. I wonder if this problem is more wide spread than what is showing up here on this board. Could it be that a lot of Cab's are not driven on or at highway speeds? I'm not giving up but I do think we need to bond together and get BMW to pay attention to this problem. Based on what I've read I don't think tire balance and/or alignment are the root cause.
FYI, Tire balance and allignment worked for me. as stated I have a rim w/ a small bend on the back so I still get a very small bit of vibration. but nothing as bad as it used to be. also check to see if your mini is mushroomed this could be screwing w/ how the wheels are hitting the concrete. I can get the car up to 70 and it does just fine. I am thinking once I flatten my very very slight mushrooming and add strut savers, get a new set of rims, Miles will be running stupid smooth.
Old Dec 8, 2008 | 02:41 PM
  #27
Sacha's Avatar
Sacha
My car had 12 km when I took delivery last March, and been doing it since day 1. I doubt it is mushroomed!!
Old Dec 8, 2008 | 02:57 PM
  #28
oxtox's Avatar
oxtox
sorry to hear about the shimmy/shake. fyi my '08 cabrio has had no such issue up to speeds 120+ @ thunderbolt/lightning. i can be obsessive, and put on strut tower plates as soon as i brought the mini home from the dealer. i don't know that low milage rules out mushrooming. my point is that if it's not the tires, alignment would be my next bet. you might also want to try a non-dealer (like helix, or perhaps madness - not sure which is closer to you) to look at the problem, they have different priorities....and in some cases a lot more experience. good luck!
Old Dec 8, 2008 | 03:40 PM
  #29
r52pimp's Avatar
r52pimp
I had the same issue I just picked up my 05 MCSCa and driving it home as soon as I went over 55MPH I got a crazy shimmy. Once back in colorado I had my pops who works at a dealer have all four wheels balanced and checked. Ends up a had a very slightly bent rim on the front and all four wheels were off balance. they moved the bent rim to the back (getting repaired in a week or so) and had all the wheels balanced as close to zero as possible.
Bam-a-lam shimmy is gone. I can feel a slight vibration from the back (most likely due to the bent rim) but the car rolls super smooth on the highway now. thank god. Getting oil change and allignment next week. I have runflat NanKangs, noisy as hell but they were on the car when i bought it and they are virtually new.
Hope this helps.
Listen to this man. I rotated my tires and got the shimmy at 55 mph. Went to my tire shop thinking one of the wheels was bent. Turned out all 4 were out of balance with only 2k on them (driving hard removes a lot of rubber). Once balanced the shimmy is gone. I am now working on unbalancing them again.
Old Dec 8, 2008 | 05:51 PM
  #30
cxg's Avatar
cxg
something still there
All tires were replaced. No alignment done (that they mentioned to me) the 'shudder' is gone, but there is still something there in the back at that speed. My thought is there is something causing the tires to become misshappen and that the shudder will be back before long?? I suspect what I am feeling is what the person who posted about having a bent rim is feeling. I bet it's not the bent rim.
Old Dec 10, 2008 | 03:34 PM
  #31
Sacha's Avatar
Sacha
My car is stored for the winter, so i'll look into it next March. I'll be getting new non-runflat tires, and wheel alignment at the same time, hope it will fix it.
Old Dec 20, 2008 | 01:15 PM
  #32
jdamann's Avatar
jdamann
Latest
Just wanted to let you all know the latest on my issues with shimmy. I have an appointment to bring the car in on December 30th. I spoke to the general manager about the problem the fact that he has another customer with the same issues. I asked if he could arrange for a regional tech to be there for my appointment. Based on all the steps taken to correct the problem on the other car that have been unsuccessful I am planning on writing a letter to Mini and begin the process to have them buy the car back under lemon law. Will keep you posted.
Old Dec 22, 2008 | 07:01 AM
  #33
drdave's Avatar
drdave
I have the same issue with my 2008 convertible (6000 miles). At 70 mph (+/- 5mph) my car shakes. I'll have to see about getting the wheels/tires balanced but my closest dealer is 100 miles away.
Old Dec 22, 2008 | 07:52 AM
  #34
srmitch2's Avatar
srmitch2
Had to put my 2 cents worth in. Have driven an 06 MCCSa (17" Goodyear RFT) for a year and a half, 16K miles, 3900 mi. summer road trip. I've had absolutely no vib problem. Asked about it amonst local Mini club, other Cabs same as mine. Suspect more isolated than wide-spread issue. BTW, who wouldn't drive a Cab, perfect for open motoring that is is.
Old Dec 22, 2008 | 03:57 PM
  #35
Sacha's Avatar
Sacha
Lots of them seems to be from some '07 and mostly '08 models........
Old Jan 5, 2009 | 04:57 AM
  #36
jdamann's Avatar
jdamann
They say it's normal
I recovered my Mini last week from the dealer after they replaced two tires and roadforce balanced all four tires. While the shimmy is much improved, it is still there. After test drives with both the service manager and the tech who did the work they did agree but said this slight shimmy was inherent in the design of the car. They took me for a ride in another '08 that had 16" wheels (all they had available). It too had a slight shimmy between 65 and 75 mph. Some of you have reported that your cars are completely free of this phenomenon. I'm not sure what to do next. HELP????
Old Jan 5, 2009 | 02:40 PM
  #37
Thirsty's Avatar
Thirsty
Mine is a 08 and has a slight shimmy also. I thought it was normal. Now I'm a bit concerned. Is it OK to leave as is? I rarely run on the freeway. When I do, 70 is too slow.
Old Jan 6, 2009 | 04:34 AM
  #38
stevehy's Avatar
stevehy
I have an 08 S cabrio and IMO no shimmy is normal and I would not accept this as a normal condition. If you read through this thread you will see that not all have this problem. The dealer saying ‘all do this’ is just trying to avoid their responsibilities and fix this.
Steve
Old Jan 6, 2009 | 09:40 AM
  #39
HRCVF750's Avatar
HRCVF750
I have a 2006 factory JCW MCS Cabrio with 8200 miles running JCW 18" wheels with Dunlop RFT and have never experienced any shimmy whatsoever. It's my daily driver and I typically average about 35 miles of both freeway and surface streets each day and I've never had a problem
Old Jan 14, 2009 | 08:49 AM
  #40
jdamann's Avatar
jdamann
I am about to go through round two with dealer
I am wondering if anyone out there that does not have this problem lives anywhere close to Annapolis. If so, would love to have you meet me at the dealer and help me prove this is not a normal condition....Thanks in advance
Old Jan 14, 2009 | 12:01 PM
  #41
matty125's Avatar
matty125
no shimmy in mine, I drive over 115mph at least every week here in germany. w/ 17in run flats
Old Jan 14, 2009 | 12:15 PM
  #42
Blont-007's Avatar
Blont-007
Here a sidewalk '08 from the Netherlands, also has the shimmy at 70 M an hour. I also now that they now it by Mini. My dealer told me that it were the 17 inch sidewalk wheels, so i put my 18 inch works wheels. But the shimmy is still there. Also have a strutbrace on it from day 1.
I also notice that when the car is warm, the shimmy go's away.
Old Feb 23, 2009 | 04:52 AM
  #43
jdamann's Avatar
jdamann
Lemon Law
Well...I sent my letter off to BMW requesting they take my car back under provisions of our states Lemon Law. Tired of dealer telling me that everything is normal. Will keep you posted
Old Apr 1, 2009 | 05:16 AM
  #44
jdamann's Avatar
jdamann
The latest
Well...I had an appointment with the regional Mini rep last week. He test drove the car and agreed there was a problem. They started by trying to re balance the tires, two of which were replace on the last visit. Then they told me those tires were so bad they couldn't get them to balance properly and offered four new Continental tires. After they were installed and balanced I took the car on a test drive and found no change. They then agreed to check the alignment. They returned the car after a four wheel alignment and some other checks. I drove the car home.....it was actually worse than before. Now Mini is telling me the car is normal. I have to make one more service visit in order to file under the Lemon Law. Also considering filing with the NHTSA (these are the guys who govern recalls) as vehicle defect. Will keep you posted
Old Apr 6, 2009 | 08:41 AM
  #45
Sacha's Avatar
Sacha
Ok, got new tires(toyo proxes4, non-runflat), wheel alignment, and the shake is ALL gone
OMG, what a difference, now I really like the way the car drives, no more rattle and shake
Old Apr 8, 2009 | 07:53 PM
  #46
Urn's Avatar
Urn
My 08 with stock 16" alloys and non-run flats shakes as well. I have not really determined at what speed it occurs. My passenger headrest shakes as a result which is quite annoying.
Old Apr 9, 2009 | 06:14 AM
  #47
Sacha's Avatar
Sacha
Yep, pretty annoying. In my case, i'm pretty sure the Pirelli Euphoria RunFlat was the culprit of all the shaking.
Old Jun 24, 2009 | 12:40 PM
  #48
jdamann's Avatar
jdamann
Latest Information
I did engage a lawyer to file a Lemon Law Claim against BMW. The initial request for repurchase has been denied. Unfortunately I live in Maryland. The attorney advised me that judges are not consumer friendly and take the case to court has low probability of winning. She has filed a case through the Better Business Bureau Auto Line. Still waiting on that outcome. In the mean time, I have filed a safety complaint with the National Highway Transportation Safety Administration. I would appreciate support from anyone else who has experienced this problem to file one as well. The web site is: www.nhtsa.org
The form takes less than five minutes to complete. Thanks in advance
Old Jun 29, 2009 | 02:10 PM
  #49
baby blue's Avatar
baby blue
Sorry for the late post but after many visits to my dealership (almost 2 hours away) and much unhappiness, I forced the dealership to replace my tires (Pirelli) that came on the car to Goodyear Eagle. They didn't like having to do it but gosh, shimmy was gone. Come to find out, they had to do the same with 3 other cars that came in on the same truck. Defective Pirelli tires is what they said.
I drive an 08 MCS.
USNAE2
16
Jun 17, 2022 07:17 AM
Jim Ferrell
Oct 6, 2015 08:09 AM
eliseo1981
Sep 30, 2015 07:57 PM
patsum
Sep 30, 2015 02:10 PM
jennster
Sep 28, 2015 06:19 PM
