R52 Has anyone had the armrest apart?
Old Aug 20, 2007 | 12:13 PM
chur's Avatar
chur
So there was no way I was going to purchase the factory Bluetooth (Wife had an aneurism when she saw the price without it), But I really hate wires and hokey things plugged into the lighter. Still I'd like a USB cord in my center console so I can charge my cell phone. I'm thinking about adding a lighter somewhere behind the dash with one of the lighter to USB adapters plugged in, then routing the USB cord into the armrest from there. Has anyone seen a better way to do this? Has anyone taken the armrest apart and wired it for anything? Any comments would be helpful.
Old Aug 21, 2007 | 10:26 AM
JoeyC's Avatar
JoeyC
Not sure if this would help...but I tied in my sirius radio to the cigarette outlet in the back trunk. I ran the wire from the outlet, under the back seat, under the carpet to the arm rest (poked a hole in the carpet). then just pushed it up under the armrest until I got to the cup holders. The only place the cable is visible is between the armrest section and the coin holder tray under the e-brake (about 1/2 an inch). I was able to live with that...
I did need to add about 6 foot to the power cable to reach that far too...just a little solder and electrical tape did the trick.
Hope the idea helps some...I would think you could take the wire up the hollow arm rest support and run it into the holder part...still would see some wire showing, but wouldn't be too bad.
Old Aug 21, 2007 | 08:19 PM
chur's Avatar
chur
That sounds like the way to go. Just buy an 8 foot USB cable and run it under the seat. Is the rear outlet switched? Some of the chargers use power all the time unless unplugged from the outlet. I'd hate to come out to a dead battery.
Old Aug 22, 2007 | 05:12 AM
JoeyC's Avatar
JoeyC
The rear outlet is switched...as I don't need to turn my sirius off when I get out of the car.
Personally, I think they should make cars so the one in the cabin is on all the time, and the one in the trunk is switched. I hate not being able to charge my phone while the car is off.
Old Aug 22, 2007 | 11:38 AM
mauleskyrocket's Avatar
mauleskyrocket
In a related question---can the angle of the arm rest be adjusted? Thx.
Old Aug 22, 2007 | 11:42 AM
Loony2N's Avatar
Loony2N
The arm rest can be moved from horizontal to (almost) vertical, but it can only be rested on in the horozontal position.
Old Sep 5, 2007 | 08:09 PM
jgg5's Avatar
jgg5
factory armrest install instructions
mossmini.com carries the factory armrest on their website under interior accessories. On the description page is an icon for "instructions". Those may be helpful if you wish to mod the armrest.
Old Sep 6, 2007 | 05:33 AM
BigGuy25's Avatar
BigGuy25
Switched cigarette lighters can really be a problem. My biggest issue is when I first plug in my portable GPS and am waiting to get a signal. You need to keep the ignition switched on to get power to the unit. I guess this is a safety issue????
Old Sep 10, 2007 | 09:40 AM
chickenplucker's Avatar
chickenplucker
Didn't see one for the '07. Are you sure they carry it?
Old Sep 10, 2007 | 10:15 AM
chickenplucker
Here's mine
Posted in wrong thread. Oops
Old Sep 21, 2007 | 10:10 AM
SuperMINIs's Avatar
SuperMINIs
Arm rest is adjustable. I usually keep it up when entering or exiting MINI. It is not very sturdy plastic and leaning body weight is not recommended.
gar56
Nov 15, 2016 06:41 AM
67morris
Dec 1, 2015 12:53 PM
jeri534
Nov 6, 2015 01:40 PM
pglgp1292
Oct 5, 2015 09:34 PM
krohm
Sep 28, 2015 12:16 PM
