R50/53 I need a Super Charger
Old Feb 22, 2007 | 10:17 AM
LakeHelen's Avatar
LakeHelen
2003 MINI Cooper S
I need to replace my supercharger. Any one have a used one for sale? Should I let the dealer do the install?
Old Feb 22, 2007 | 10:43 AM
Alex@Helix's Avatar
Alex@Helix
I have a 2003 supercharger with about 40,000 miles on it. It comes with a 15% pulley. Asking $350.
Let me know if you are interested.
Old Feb 22, 2007 | 11:27 AM
Yo'sDad's Avatar
Yo'sDad
I don't have one, but may I ask what happened to your SC. I'm trying to gather info on what fails first in these things.
YD
Old Feb 22, 2007 | 11:51 AM
ImagoX's Avatar
ImagoX
I've heard that heating the supercharger pulley shaft (sometimes done to remove a "sticky" OEM pulley assembly) can cause the seals to blow out... beyond that, I'm curious as well.
Old Feb 22, 2007 | 12:06 PM
DrkSlvrS's Avatar
DrkSlvrS
The water pump drive gear is driven by a SC drive gear - gears are incased separate from SC - are never lubed after the factory - lube dries out around 100k miles - without lube, metal on metal tends to have disastrous results - gears alone cannot be replaced - must replace complete SC.
I had to replace mine at 120k.
T
Old Feb 22, 2007 | 01:23 PM
ImagoX's Avatar
ImagoX
Can they be reached to be lubed, or are they sealed? Seems like something to add to the list of things to do around 80k-90k miles...
Old Feb 22, 2007 | 01:29 PM
Eric_Rowland's Avatar
Eric_Rowland
There are fill holes, but you need to remove the SC to get to them and R&R the fluid. I don't think I'd say the lube 'drys up', but it does tend to weep out of the mating surfaces over time.
Old Feb 22, 2007 | 06:03 PM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
Look on E-bay, there is a brand new one there,
Old Feb 23, 2007 | 03:47 AM
LakeHelen's Avatar
LakeHelen
I am not sure why my SC failed. Started with some intermittent noises from that area,at first I thought (hoped) it was the belt tensioner.
I read through the Bentley manual on this remove and replace and not sure if I want to do it myself. I don't know of any MINI mechanics in the area except for the dealer (Orlando, FL). Calling today to see if I can provide a used SC to the dealer for them to install.
Old Feb 23, 2007 | 05:26 AM
jibeho's Avatar
jibeho
Ian at Trick Pro in Melbourne knows his way around a Mini wery well!
Old Feb 23, 2007 | 08:08 AM
LakeHelen's Avatar
LakeHelen
Can anyone tell what year Superchargers are interchangeable??
I had a deal on a new 2005 SC but the dealer told me it was different that the 2003.
Old Feb 23, 2007 | 08:40 AM
Eric_Rowland
Only difference would be in the coating - '05+ supposedly have a performance enhancing coating on the lobes. Should bolt right up.
Old Feb 23, 2007 | 08:43 AM
Partsman's Avatar
Partsman
Legion_of_Doom
That's the only thing I could think of as well, realoem.com shows one number up to 07/04 for a reman SC, and a different number after 07/04.
Old Feb 23, 2007 | 09:04 AM
C4's Avatar
C4
The factory SC fitted to 2005+ MINIs is the same Eaton unit used in the original JCW 200HP performance kit upgrade. This would be for cars manufactured after July 2004.
Old Sep 11, 2007 | 07:43 PM
Green Goblin's Avatar
Green Goblin
I just go a new supercharger I'd let the dealer do it. if you have warranty becuase it would have costed any where from $2300 and up mine was like $2700 W/O coverage becuase mine is a JCW but luckily I have extended up to 100,000 miles.
Old Sep 11, 2007 | 07:45 PM
newbs49's Avatar
newbs49
Try this
https://www.northamericanmotoring.co...1&goto=newpost
SneedSpeed
Oct 1, 2015 03:01 AM
patsum
11
Sep 30, 2015 02:20 PM
fkrowland
Sep 30, 2015 10:30 AM
dgamblin
Sep 29, 2015 10:06 AM
jennster
Sep 28, 2015 06:19 PM
