R50/53 Fog Lamp
Old Oct 16, 2006 | 07:01 AM
Minzila's Avatar
Minzila
Fog Lamp
I noticed this morning that one of my fog lamps was not working. The dealer wants $22.75 for a replacement. Any other options? I'm talking about the stock one in the bumper, not add ons.
Thanks.
Minzila
Old Oct 16, 2006 | 07:07 AM
Mr. Pep'r's Avatar
Mr. Pep'r
Replace it yourself, I am sure you can get the bulb at NAPA or AutoZone.
If you can not do the work then it is only $22.75.
Old Oct 16, 2006 | 07:42 AM
ScottinBend's Avatar
ScottinBend
I think $23 bucks for a maybe $5 bulb is about right from a dealership. And remember that they will probably charge you for labor too LOL
Removing the bumper is very easy. Just do a search for instructions.
Old Oct 16, 2006 | 08:09 AM
ProfessorDave's Avatar
ProfessorDave
I'd gladly pay that to avoid removing the bumper (which is not difficult, but not worth it to me for that price). I'd replace both bulbs regardless of whether they do the work or you DIY.
Old Oct 16, 2006 | 09:04 AM
Minzila's Avatar
Minzila
Fog Lamp
Thanks for the replies, but I guess what I'm asking is, does anybody know a part number (Oshram, GE, Sylvania). It looks like it can be changed from the wheel well.
Minzila
Old Oct 16, 2006 | 10:00 AM
Smokey's Avatar
Smokey
Minzila
No part number for you........... but you are correct; you replace it through the wheel well. If you pull the bumper the fogs stay on the car, only the turn and running/parking lights are bumper mounted.
I'd strongly recommend you get some (10 ea) of the plastic screw-clips as they can be mangled / stripped when you remove them.
Old Oct 16, 2006 | 01:36 PM
chows4us's Avatar
chows4us
Minzila
The bulbs are H11s. See http://www.rallylights.com/hella/H11.asp $12 for Hellas each.
$23 is not bad if you include the labor.
Old Oct 16, 2006 | 02:14 PM
Minzila's Avatar
Minzila
Fogs
Thanks, that's the answer I was looking for. The $23 price the dealer quoted was for the bulb only.
Minzila
Old Oct 16, 2006 | 09:27 PM
Rawhyde's Avatar
Rawhyde
Having spare parts on hand is always a good idea!
I think you can take loose the lower screw for the inner fender (actually in the bottom of the bumper cover) and peel it back enough to reach the bulb. That way you can leave the other dozen of the easily strippable screw-clips in place.
Chows says H11, I think they're H7 bulbs. I also think that there was a change sometime during production. Check your owners manual...maybe the bulb is listed there.
HERE IS A VERY GOOD TECH TIP
ALWAYS take a new halogen bulb out of its packaging and clean it with a fresh paper towel and alcohol. Once it is cleaned, handle it ONLY by the metal base. If you touch the glass, wipe it with alcohol again before installing it. The instructions will caution you against touching the bulb, but you don't really know if someone may have touched it at the factory before it was placed in it's package. Do it right, and it'll last a lot longer.
Rawhyde
PS My next post will put me into 5th Gear!
Peking Duck
Jan 19, 2021 03:17 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
aldito2
Sep 30, 2015 10:44 AM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
