R50/53 Things You Didn't Know About Your MINI
Old Nov 8, 2007 | 05:43 PM
  #1001
mauberley's Avatar
mauberley
Congratulations to this thread on hitting 1000 replies!
Old Nov 8, 2007 | 07:15 PM
  #1002
Miniriffic's Avatar
Miniriffic
Originally Posted by MR ECON
If you touch the key to your chin or cheek while pressing the unlock button, the key will unlock your MINI from a much greater distance.
I"ve tried this and it works. Why, though????
Old Nov 8, 2007 | 08:18 PM
  #1003
Minidrivr's Avatar
Minidrivr
Works with just about any transmitter (car alarm, gate/door opener). The car audio guy who first told me about this while installing a car alarm for me said it was due to dental fillings. Some here have mentioned it is just due to your skull amplifying the signal.
Old Nov 8, 2007 | 09:01 PM
  #1004
JustJAY's Avatar
JustJAY
Just a tip for everyone posting, make sure that the tips are for 1st and 2nd Gen and not 2nd Gen only.
I haven't read through this thoroughly, but I have seen some sigs of 2nd Gen MINIs and just want to make sure everything is clear.
Old Nov 14, 2007 | 10:40 AM
  #1005
PrplPplEtr's Avatar
PrplPplEtr
Originally Posted by David Bremmer
Now this is a very useful find for surf doggies on the left coast. I must try it.
I insisted thay my wife get racks for her Mini. For surf trips using her Mini, I have been using the valet key because salt water is not kind to the battery powered keys.
careful with that. my SA told me that the emergency key had a limited number of uses due to its plastic construction.
Old Nov 15, 2007 | 07:38 AM
  #1006
Ferroequine's Avatar
Ferroequine
I think we all know that when you press the unlock button, the front, side and rear indicator lights will flash twice.
However, if instead you press the "boot unlock" button, you will only have the side and rear indicator lights flash. The fronts stay dark.
Old Nov 17, 2007 | 10:02 PM
  #1007
2ndhandMINI's Avatar
2ndhandMINI
At temps below 37, it chimes a warning.
Old Nov 17, 2007 | 11:02 PM
  #1008
MR ECON's Avatar
MR ECON
I'm no rocket scientist, but perhaps its like putting a bigger antenna on your radio or TV. I've been hoping someone with expertise in this matter might provide a more technical explanation.
Old Nov 18, 2007 | 10:58 AM
  #1009
Sin MINI's Avatar
Sin MINI
The cavities in your head (sinuses, etc) amplify the signal.
Old Nov 18, 2007 | 12:38 PM
  #1010
daffodildeb's Avatar
daffodildeb
This happened to come up yesterday, when Hubby had the key and I needed to get into the car. He was quite a distance away (I had to shout), and slightly downhill. He held the key up high over his head. No luck. I shouted back to hold it touching his cheek, and it opened right up! My engineer husband was baffled.
Old Nov 18, 2007 | 10:28 PM
  #1011
MR ECON's Avatar
MR ECON
You're pulling our legs, right? Surely there must be someone out there who
knows the real answer. Ann Landers?? The Playboy Advisor??
Marilyn Vos Savant?? Anyone??
Old Nov 18, 2007 | 10:34 PM
  #1012
Eric_Rowland's Avatar
Eric_Rowland
The body acts as an antenna.
Don't believe me? Are you old enough to remember TV rabbit ears? And how the signal would get better when someone touched them, but degrade when they let the ears go?
Old Nov 18, 2007 | 10:44 PM
  #1013
ScottRiqui's Avatar
ScottRiqui
Yep - your body's acting as a "passive radiator", extending the range of the remote transmitter.
Sometimes you'll have the same thing happen near large concrete buildings - the mesh of metal rebar in the concrete walls will pick up the signal and re-radiate it. Power lines (or any kind of nearby wiring) can also do the same thing.
Old Nov 18, 2007 | 11:42 PM
  #1014
Sin MINI's Avatar
Sin MINI
For what it's worth, I'm an engineer with experience with radar systems. Trust me. Go read about magnetrons and cavities.
Old Nov 19, 2007 | 04:22 AM
  #1015
umberto's Avatar
umberto
"The cavities in your head (sinuses, etc) amplify the signal"
this improvement of range of the remote when next to your head....I discussed this with my wife and how it is the cavities in your head and how this technique really works well for me...she looked at me and said: obviously! Perhaps it works better for some and less in others?
Old Nov 19, 2007 | 11:04 AM
  #1016
preludestuntin's Avatar
preludestuntin
I would have to say you're right. It does work for me, but sometimes when my fiancee and i are walking out to the car from a store (like Wal-Mart or something) I'll put the key up to her head and press the un-lock button and it works from a greater distance than if I were to put it up to my head. She isn't really too amused by it
Old Nov 19, 2007 | 01:36 PM
  #1017
MR ECON's Avatar
MR ECON
The antenna theory seems most logical to me, but I'm open to the cavity
theory as well. I'll look into the latter--the theory, not the cavity.
Old Nov 19, 2007 | 02:06 PM
  #1018
mauberley's Avatar
mauberley
The two theories aren't actually separate. So don't worry about neglecting one over the other.
Old Nov 19, 2007 | 03:17 PM
  #1019
MotorMouth's Avatar
MotorMouth
The cavities in your head help range? Shoots, mine should work a country mile away then!
Old Nov 19, 2007 | 06:15 PM
  #1020
mmatarella's Avatar
mmatarella
I stood in conference room with a all glass outer wall overlooking the parking lot, and opened my windows and lowered my convertible top from about 350 feet away. Amused my fellow meeting victims.
No cavities, held a butter knife vertically with the tip of the key touching it out in front of me. Extended the range quite a way. I'd suggest a capacitive link with your body acting as a extended antenna. Google human body and antenna theory and you can read all night. :-) I've also extended the range to a lesser degree by touching it to my chin, or with the tips of my index and middle finger of the other hand held vertically in line with the key. You could carry around a nice metal mixing bowl too.
Old Nov 23, 2007 | 11:08 PM
  #1021
Marwan's Avatar
Marwan
Hey guys, how does this work? How can I do it??
The UNLOCK button when held in will roll down all the windows and open the sunroof unless it has been de-activated.
I've a 06 MCS.
Old Nov 24, 2007 | 11:17 AM
  #1022
LowCountry S's Avatar
LowCountry S
have to agree with the passsive antenna theory ( also was a radar/electronic tech at one time in my life ); don't any of you "older" drivers remember having to "strike a pose" while holding the rabbit ears on the TV?? same principal I'd imagine. And to preludestuntin, I wouldn't say ANYTHING about the cavities in her head being bigger so they're better antennas if I was you!
Old Nov 24, 2007 | 01:06 PM
  #1023
Mini2Go's Avatar
Mini2Go
Coordinator :: Pitt Stop MINI
I've a 06 MCS.
I've added emphasis to the quote because I'm assuming that is the part you are asking about - right? If so, then simply hold the UNLOCK button down for a while - let's say 6 or 7 seconds - and you'll see things open up. (NOTE: All doors must be closed for this to work.) I know this works with the key, but I was told it also works with the unlock toggle - although I've never bothered to try, so I cannot verify).
Old Nov 25, 2007 | 12:04 AM
  #1024
Marwan's Avatar
Marwan
Daytime running lights can be programmed on or off per the owner's wishes.
How do I use/program those options? The daytime running lights and the unlock button thing?
Old Nov 25, 2007 | 04:02 AM
  #1025
Marwan's Avatar
Marwan
Thanks! This is what I was looking for clarification for: the toggle key.
Another thing, my car does not close windows up/ open windows down from the key remote control. If I keep pressing the lock or unlock buttons nothing happens. I know other Minis do but not mine. Any clues?
