R50/53 Things You Didn't Know About Your MINI
also, the fuel door locks only when you have locked the doors with the key button.....the fuel door does not lock when the doors have locked automatically at 8mph.....for quite a while, when I would pull into a gas station I would unlock the doors because I wanted to unlock the fuel door but then noticed that the doors could stay locked and the fuel door could still be opened
Originally Posted by paulr
The factory radio will always restart at a reasonable volume level, regardless of how loud it was when the MINI was turned off.
Originally Posted by motor on
Even if you don't have the OBC the tach display still comes with the avg, kph, mpg, range displays built-in
Convertible top..
Did you realize that while you can't put the top down while moving forward, you can raise the top while backing slowly.
Now, I don't want to hear about a bunch of you testing this carlessly and running over family and pets...
T
Originally Posted by SCoop
How do you access them? I've read through the entire 14 pages of this thread and couldn't find that answer. At least one other person, maybe two, also asked about this.
Originally Posted by DrkSlvrS
I'm pretty sure the fuel door locks whenever the locks are engaged - with the fob, the consol switch or (if enabled) at 10mph. The fuel door is unlocked whenever you unlock the driver's door (either by double pulling it from inside or using the fob or consol switch).
T
T
been my experiance
Originally Posted by petecrosby
That's a dealer enabled option.
Originally Posted by Newdl
When I go to the dragon next year, I think I am going to be bringing one of my winter tires with me incase of a blow out. This gives me the advantage of simply swap and go. Sadly with 1 wheel different than the others.
~Neal
~Neal
Make sure to put the 15" wheel on the rear. If your blowout is on the front, put the unaffected rear tire up there, then install the 15 on the rear.
Mismatched wheels on the front would put SEVERE wear on a Limited Slip Differential. Even a non-LSD car would experience abnormal wear on the spider gears with mismatched wheels.
Rawhyde
you can get to it throught the hidden OBC (hold trip button while turning key see MINI2 FAQ DIY) and the test function just to get the light, can also run a search for OBC DIT adventure.
Originally Posted by Hu99
Important to note for those who will be rolling their eyes at the thought of dealers using this power to make money, they are not to charge for this service per BMW service bulletin M090102 http://www.alldata.com/tsb/BMW/11334...02/901021.html
Originally Posted by rkw
It is merely a recommendation if you interpret the words carefully ("should"). My dealer gave me one free opportunity to specify my settings, and said that subsequent changes would be charged.
Is there a way to turn off the overhead orange lights that guide the way to the map lights? It puts a shadow across the speedo that's a bit annoying. I could always do something like plug 'em but I'd rather disable them.
mine didn't mention user-pref setting change options at delivery... thought it's free to change them... if I drive back tot he dealership, which is far. So I'm just going to bide my time until service... I was surprised to hear that no-fee scheduled maintenance had to be done at the dealer who sold you the car. Is that true?
Originally Posted by Minitee
I've experienced the same thing = touching to head (temple or chin usually) increases distance. Trying the same orientation & elevation but further away from the body/head doesn't work as well.
Who ya gonna call? Mythbusters!
Yes, the new owner is not charged for that. But the note also says, "Selection
changes during the ownership period are not reimbursable under warranty". This means
you get one free set-up at delivery time and after that you will be charged. No, I don't
like it either but that's the way it is.
You are taking this out of context. The note describes the options to be set at delivery.
Your scheduled maintance shoud be able to be done at ANY dealer.
I purchased mine and have had all maint done at the more local dealer.
I was told that they are "reimbursed" from MINI for ACTUALL WORK DONE.
