R50/53 Emergency help!!! how to close the bonnet
Some things to try:
Work the bonnet pull lever a couple of times to be sure it moves freely.
Look at the latch mechanism under the hood. Is it in the 'catch' position or in the 'lock' position, preventing it from catching with the opened bonnet above?
Try flicking the latch mechanism a couple of times with your fingers to be sure it's not stuck.
Drop the bonnet from a bit higher, or give it a more swift downswing (don't go crazy though).
Once down, press firmly downward on both headlamps at the same time.
i usually drop it from about 2 feet and continue to push down on the grill
gently as it locks. mine is a bit tough to close too.
I had the same thing happen where the gap on the driver's side w/ the bumper was VERY large.
I just needed to push down HARDER as I closed it.
I even asked at mini and their comment was "don't be shy, CLOSE the hood don't dance around it hoping it'll lock"
I once didn't drop MIB's Bonnet from high enough. The driver's side latched and the passenger side didnt. I had to go to the passenger's interior and pull the release. That allowed the drivers side of the bonnet to release so that I coud pull the lever to release the bonnet and raise it. Now I always make certain to drop the hood from 2 feet or so. I also give it a little push just before releasing.
Hope that this helps you!
OMGGGGGoooddd
I shut it REALLLYYY hard i slam it like crazy and it shuts HAHAHAHAHAHAA
thx for all the work guys
PROBLEM SOLVED i am going to drive it now
THXTHXTHXXXXxxx u guys a really gddd , very effective
Well, if it doesnt latch completely, and youve never opened it before, then the hatches must be a little too far down. they are obviously within range for the bonnet clips to reach them(otherwise it wouldnt have ever been closed)
Easily solved. they are not hard to re-adjust. MINI should be able to do it for you also. it would take all but a few minutes to do it yourself. I believe they are 13mm bolts. just loosen a bit, and raise up the hatches...simple as that..
I'm curious as to whether this works for you...let me know if you try it
Addam
Addam
I dunno I never have to slam it or push on hoods,I drop from 2 feet.Most car companys dont advise leaning on hoods.The only ones Ive seen with this problem are ones with strut bars that interfere with hood insulation.
mine doesn't close from a drop either, gotta push
down on/near the headlamps while the hood is closing. several others have posted the same observation
Originally Posted by mondsiu
it's my first time open it..
won't close when i drop it down, it goes bac to that position where u need to pull that lever to open the bonnet
i can't close the bonnet completely !!!
