R50/53 Dorky cheapskate modification
Old Sep 25, 2009 | 03:09 PM
  #351
M315motoring's Avatar
M315motoring
I used black pin stripe to mask out the chrome trim along the bottom of the windows.
Old Sep 25, 2009 | 03:31 PM
  #352
89AKurt's Avatar
89AKurt
Originally Posted by jbell
its not a graphic btw. its a texture.
Like it's all black, then ironed or molded? That's more real than decals (I'm thinking scale model cars).
You get the ring around the shifter yet?
Old Oct 18, 2009 | 04:13 PM
  #353
dosomething's Avatar
dosomething
just put these checker decals on my r53, and it cost $28 put my 20min time to put them on. I think it looks good.
[IMG][/IMG]
Old Oct 18, 2009 | 04:15 PM
  #354
dosomething
Old Oct 18, 2009 | 04:23 PM
  #355
hoonpv's Avatar
hoonpv
Old Oct 22, 2009 | 08:45 PM
  #356
8th_note's Avatar
8th_note
Did my first cheap mod today. I decided to paint my windshield wiper arms - white. I also found the box that had my England license plates. This should be fun until I have to put my Montana plates on.
Old Oct 23, 2009 | 10:12 AM
  #357
clownphish's Avatar
clownphish
Originally Posted by xtremepsionic
Haha Brilliant! The only cheap dorky mods I have is a 1:1 scale sticker in the back its cheap because I cut it out with scissors and adhesive white labels
http://www.mini2.com/galleries/data/...m/IMG_4514.jpg
Ha! That is awesome. I'm a civil drafter and that made me chuckle. :p
Old Oct 23, 2009 | 12:19 PM
  #358
NightFlyR's Avatar
NightFlyR
Ok here is my cheapest MOD and you dont even see it.
one 4 x 3, 1 inch thick rubber welcome mat, you know the ones you wipe your feet on when you come in the house,cut in half, lifted up rear seat and perfect fit, quickest sound insulation I have done. Cost about 4 bucks and the difference in the noise coming into the car on the highway was dramatic. granted it weighs 3 pounds or so.
Old Oct 26, 2009 | 10:01 AM
  #359
clownphish's Avatar
clownphish
Hmm that sounds damn worth it....
Old Oct 27, 2009 | 11:34 AM
  #360
jbkone's Avatar
jbkone
Really? Under the rear seat? Like where the rear passenger butts go? That sounds too easy! And I've been wanting a quieter MINI since day 1.
Old Oct 28, 2009 | 03:02 AM
  #361
vodka's Avatar
vodka
"1 inch thick" doesnt it make the rear seat higher? Still comfortable as usual? Btw, its a niice mod.. tempted to try
Old Oct 28, 2009 | 06:08 AM
  #362
NightFlyR's Avatar
NightFlyR
I had no problems with the fitment, No one really sits in my back seat but it wont be an issue, just some extra cushin. I would tell you to try and get a thick Matt and one that has that artificial turf or carpet on top, and lay that side towards the car with the rubber side up, that is how i did mine.
Old Nov 3, 2009 | 06:41 PM
  #363
vodka's Avatar
vodka
I just tried that and it work... ok, it not super quiet but I can feel it, it does help.... cheapest way to sound proofing
Old Nov 16, 2009 | 06:32 PM
  #364
steelz21's Avatar
steelz21
I made the intake grille from heat moulded rubber and mesh tape. Total cost $5.
Made the tailpipe trim fit with lots of cutting and filing. It was a single 2.5 inch inlet, but now fits the standard dual exhaust outet. Total cost $45
Attached Thumbnails Dorky cheapskate modification-red-inlet.jpg   Dorky cheapskate modification-oval-tailpipe-close-up.jpg
Old Nov 18, 2009 | 11:18 AM
  #365
maxmini's Avatar
maxmini
Nice work but I would lose the screen . The stock intake path does not need any more help in restricting the air flow. Any foreign material coming in through that opening will be picked up by the air filter further down stream.
Randy
M7 Tuning
Old Nov 25, 2009 | 06:14 PM
  #366
steelz21's Avatar
steelz21
Since those pictures were taken I have installed a K&N Typhoon intake, hopefully this will even out the mesh restriction.
Old Feb 15, 2010 | 10:18 AM
  #367
joe_bfstplk's Avatar
joe_bfstplk
ROFLMAO!
Originally Posted by 89AKurt
Couldn't resist.
My only mod is a cheapy, but is invisible. I did the re-routed vacuum hose trick for the bypass valve, so that boost helps close the valve all the way, since the internal spring seems to have squashed a bit and doesn't hold it closed when there's no vacuum.
All it cost was a few bucks for the vacuum hose and tee, and the car makes much better power at lower RPMs now. One of these days I'll disassemble it, stretch (or replace) the spring, and adjust the setscrew to ensure the valve closes all the way....
C ya,
Dutch
Old Feb 15, 2010 | 01:24 PM
  #368
Mintendo DS's Avatar
Mintendo DS
C ya,
Dutch
Would you happen to have any pics to show how you did it? I'm quite interested.
Old Feb 15, 2010 | 01:42 PM
  #369
joe_bfstplk
It's really quite easy.
There are instructions Andy@ross-tech.com put together on the site here. My installation notes are linked, and the original instructions are at the beginning of the thread. IIRC, Andy's pics were excellent, so I doubt you'll need any pics my old, crusty camera will be able to provide, but I'm willing to go snap a few if you don't find the existing ones adequate.
HTH!
C ya,
Dutch
Old Feb 15, 2010 | 04:17 PM
  #370
Mintendo DS
Thanks for the info! Can't wait to give it a try.
Old Feb 16, 2010 | 03:35 PM
  #371
TX1911fan's Avatar
TX1911fan
Thought I'd throw in my cheapie mod too. I actually haven't done it yet because I don't have my actual plates, but as soon as I do, I'm going to put velcro behind the plate holder on the boot so that when i shut the hatchback door I don't hear that damn plate rattle. Easy and $0 since I already have the velcro.
BTW, I'm using velcro in case I want to remove the plate for any reason, maybe for cleaning. Otherwise I'd just use double sided 3M tape.
Old Feb 22, 2010 | 06:41 PM
  #372
Haseo461x's Avatar
Haseo461x
Here is the sub-$100 alternative to the JCW dash:
(thanks to dr.phil for the photo)
where is the best place to get the CF wrap?
Old Feb 28, 2010 | 08:59 AM
  #373
plasticknives's Avatar
plasticknives
DIY rear seat pull straps made out of nylon material my girlfriend had around the house. Stitched loops on the end, but I still want to put an eyelet where it attaches to the headrest:
Old Feb 28, 2010 | 04:57 PM
  #374
MacLeod's Avatar
MacLeod
Coordinator :: Annapolis Mini Motoring Club
That looks absolutely fantastic!! I love it!! How hard is it to do for a newb? I'm kind of a perfectionist (I think most of us are, who am I kidding?) but I LOVE that look!!
Old Feb 28, 2010 | 06:11 PM
  #375
joe_bfstplk
Looks great! The thing that really caught my eye, though, was that cupholder thingie.... Where'd you get it?
C ya,
Dutch
