R50/53 Supercharger service, plus a few other items
Old Nov 2, 2025 | 07:24 AM
  #51
phone_cover's Avatar
phone_cover
Originally Posted by ssoliman
thats what I was thinking. still waiting on the new cap / bolt with crush washer. waiting on delivery but not sure yet what I will do.
seems like its accessible from the top. so I could always do it later when I have the valve cover off.
now I'm feeling like I should have pulled the valve cover and done the chain, sprockets, guides. How important is replacing the chain and sprocket as a maintenance item (not currently having any issues at ~160k miles)
trying to avoid scope creep on this round of work
i feel you on managing scope creep. incrementally, though, the whole timing kit isn't much more work from what you already had done. that said, you're not in much danger of hurting anything extra so don't sweat it at this point.
if/when the guides fail you'll hear chatter from the engine and you'll have to pull off everything you just did. but, as you know by now, it's really not that bad of a job.
Old Nov 3, 2025 | 03:24 PM
  #52
ssoliman's Avatar
ssoliman
incrementally, it seems like the right thing to have done, in hindsight. after looking in to it a bit more, it seems the timing is really easy on this motor. it would have been one extra step, removing the valve cover
Old Nov 3, 2025 | 03:25 PM
  #53
ssoliman's Avatar
ssoliman
Originally Posted by Here2Go
​​​Well not much help but more of an admission to stupidity and guilt. I too spent an inordinate amount of time cleaning up all that grease from a torn inner axle boot while refurbishing my axles. After all that work only to discover, again, grease was everywhere after my first drive - I had forgotten to burp the inner passenger side axle boot. A mistake I'll soon never forget. A kindly tip from my own faux-pas...
Make sure you burp the boots.
yes sir, i did burp them, but almost didn't
Old Nov 3, 2025 | 03:31 PM
  #54
ssoliman's Avatar
ssoliman
more work.
-new oil filter housing and heat exchanger
-installed powerflex inserts for the trans mount
-repaired oil pan plug threads
Old Nov 4, 2025 | 03:43 AM
  #55
Here2Go's Avatar
Here2Go
NAM Community Team
more work.
Ha,ha - Glad to see you hadn't used the powerflex.com pictures for reference when you installed the gearbox bushings. I don't mean to criticize PF but their trans bushing insallation reference pics for the bushings on an R53 are installed backwards!.
I was working on multiple replacement parts and repairs to shifter cables and upgrading to PF trans bushings which took longer than expected. I had forgotten which way the original trans bushings were installed. I went ahead and installed the new PF trans bushings the way PF had them facing on their website. I eventually figured out something didn't look right after putting everything back together.
I took everything back apart and flipped the bushing in the correct orientation. Mind you; it wouldn't have been so aggravating if I hadn't been for just freshly painting my trans mount & support bracket. Nothing worse than messing up a nice paint job.
I let Corey know about the pics. But I don't remember if they ever fixed on their website
Old Nov 4, 2025 | 06:04 AM
  #56
phone_cover
those bushing on the trans mount make a big difference!
my mount was partially corroded and the bushing was shot, so i bought a new chinese mount and installed powerflex bushing inserts.
Old Nov 6, 2025 | 10:55 AM
  #57
LukasH's Avatar
LukasH
sorry did not included enough detail
the chain is in place. will not be doing the chain, tensioner rails, sprockets etc this round. the valve cover is not coming off this time and the chain cover is already back on.
compressed or uncompressed?
Yesterday I replaced a timing chain tensioner and I thought, let's give the uncompressed option a go.
Boy was I wrong! It is doable and I got there in the end but it took me a long time to press on the bolt, turning it as you go and find the first thread to get it situated.
I don't think I will do it again because I was fighting it in an awkward angle for about 30min.
Old Nov 6, 2025 | 01:42 PM
  #58
Here2Go's Avatar
Here2Go
NAM Community Team
Timing chain -
I'm going to try to tackle this job myself...soon.
These are all great insight.
I'm not sure if I will be replacing the chain though.
Very good thread. I'm enjoying reading and following along.
Old Nov 6, 2025 | 06:46 PM
  #59
ssoliman's Avatar
ssoliman
more work today
-resealed the water pump side of SC with high temp gasket maker
-changed the oil on the SC
-started on reassembly (did not take a pic. ran out of sun)
I got stuck on the throttle body. the bracket, off the trans, is not lining up with the mounting points). anyone seen that?
Old Nov 7, 2025 | 01:17 PM
  #60
Scoobaru2010's Avatar
Scoobaru2010
@ssoliman nice work so far!
Ahh yes the pesky throttle body bracket... ensure your plastic charge pipe is properly installed. That small wide rubber hose can be a bugger. After that loosen the bracket, test fit the throttle body. Remove the throttle body gently and tighten the bracket, then reinstall. Patience is your friend here for sure. Best of luck
Old Nov 8, 2025 | 05:13 AM
  #61
phone_cover
similar to scoobaru above, as i remember, i had it all fit loosely as i assembled and had to coax it all back together. then when it was fairly straight i was able to start tightening down things.
that plastic charge pipe in particular, i remember lubing the green gasket with some spit to get it completely mated.
Old Nov 8, 2025 | 05:21 AM
  #62
ssoliman's Avatar
ssoliman
yes sirs, right again.
what worked for me was leaving the two bolts on the bracket loose, very loose. once I got the four bolts on the throttle body tight, I tightened the bracket. access from under throttle body
some rubber assembly lubricant on the horn gasket. or penetrant spray helps. same for the oring on the water pump
Old Nov 8, 2025 | 05:34 AM
  #63
ssoliman's Avatar
ssoliman
more work yesterday.
-fixed the one broken vacuum line and got them installed
-got the throttle body (and charger) back on
-new crank position sensor oring
-some heat wrap on the ac and alt cables
-installed new brake reservoir
im on the home stretch yall
need to bleed brakes and adjust e-brakes. and CLEAN (engine, suspension, subframe, power steering)
Old Nov 8, 2025 | 06:01 AM
  #64
ssoliman's Avatar
ssoliman
here is the line that broke, its an offshoot of the line that goes from the throttle body to the purge valve.
the nipple broke off in the rubber side.
anyone know what this line if for?
best fix?
the generic vacuum line fitting from Dorman worked. to get the fitting on to the plastic hose I had to heat it. used a heat gun. it went in but not as far as I would have liked.
Old Nov 8, 2025 | 05:56 PM
  #65
ssoliman's Avatar
ssoliman
quick update and a question
-bled the brakes and clutch
-tried to adjust the parking brake, failed
-continued re-assembly. ready for a test start. need to get some engine oil and coolant
any tips on adjusting the parking brake? right side locks, left does not
some pics:
Old Nov 8, 2025 | 08:20 PM
  #66
Here2Go's Avatar
Here2Go
NAM Community Team
Absolutely awesome work!
​​​If it's not too much of a PIA - Before you commence to bleeding the hydraulic system; I might suggest adhereing a strip of Gorilla tape along the back edge of the brake fluid reservoir (like where the old one had split). Believe me when I tell you that it will save you from having to buy
a new one next time around. I've done this to mine and has lasted/ prevented against degrading three years now going strong.
Old Nov 9, 2025 | 09:17 AM
  #67
ssoliman's Avatar
ssoliman
thank you for the tip. I thought about it after getting it back on.
going to pick up some tape and try and get it in place with out removing it. might have to take it back out
Old Nov 10, 2025 | 06:36 AM
  #68
phone_cover
the parking brake on my mini didn't work very well when i bought it. after investigation and attempts to adjust it, i found that one caliper needed to be replaced. once i did that the parking brake worked perfectly.
i found steps for adjusting it, but if i remember, it was something along the lines of 2 clicks up and it should start to grab and like 4 clicks up should be able to hold the car. i don't remember exactly, but the process was based on how many clicks up and that was how to set the tension.
Old Nov 10, 2025 | 11:45 AM
  #69
ssoliman's Avatar
ssoliman
i found your old thread. looks like in your case it was a frozen caliper.
that could be my issue. however i did just recently rebuild them. looked good. also was able to push the piston back in. although i'm not sure it was all the way in. not sure how far back it should go. It went back a few turns from where it was and i have new (thick) pads
Old Nov 10, 2025 | 06:33 PM
  #70
phone_cover
If you already worked on your calipers then they're probably fine. The main thing I remember was that the parking brake cable didn't activate the caliper so that was an obvious issue haha
Old Nov 13, 2025 | 06:21 PM
  #71
ssoliman's Avatar
ssoliman
update, got very close to finishing this round of maintenance today.
-filled and bled the cooling system
-engine oil
-heat taped the brake reservoir (along the back)
-fixed parking brake issue (more on this in a sec)
-replaced shift **** (aftermarket **** broke on me)
started the engine after turning it with the starter for a bit (spark wires disconnected). started. no leaks that I can see yet. engine temps were good. however my low speed fan did not come on. looks like the infamous fan resister died on me. I believe it's original, so fair enough. I ordered a new fan
the parking brake. turns out, the piston was not moving with the parking brake or brake pedal. seemed to be frozen. as some suspected. I took the caliper off and used the special tool to turn it out a bit. pressed the brake and it was moving again. fixed.
apparently it was my mistake. I over pressed the piston. pushed it back too far / hard. didn't even know that was possible. lessen learned
back on the ground. waiting for the fan. in desperate need of wash
Old Nov 13, 2025 | 06:27 PM
  #72
Here2Go's Avatar
Here2Go
NAM Community Team
Now - Let's not forget about polishing out those headlight lenses .
Impressive amount of work btw!!!
Old Nov 13, 2025 | 06:50 PM
  #73
ssoliman's Avatar
ssoliman
way overdue!
Old Nov 14, 2025 | 09:51 PM
  #74
Scoobaru2010
@ssoliman great work, promising results. Interesting hangup on the caliper but good to note. Hopefully happy motoring ahead! Enjoy the finishing touches
Old Nov 15, 2025 | 06:03 AM
  #75
ssoliman's Avatar
ssoliman
@Scoobaru2010 thank you Sir. feels good to make progress. still more to do but progress none the less
yesterday I gave it a good wash. the paint is showing its age. but I'll deal with that later
