R50/53 Supercharger service, plus a few other items
Old Oct 23, 2025 | 06:08 AM
  #26
ssoliman's Avatar
ssoliman
more good stuff showed up in the mail
Old Oct 23, 2025 | 06:11 AM
  #27
ssoliman's Avatar
ssoliman
***question on the supercharger***
is it a good idea to seal the water pump side with high temperature gasket maker?
seems like the oil might have escaped / leaked out from this side as a common issue.
Old Oct 23, 2025 | 09:31 AM
  #28
phone_cover's Avatar
phone_cover
that vacuum line should work with generic connectors like you got.
i don't remember what i did on mine with the water pump. i think i searched online and found that no one used RTV, but i can't remember with any certainty.
Old Oct 23, 2025 | 07:58 PM
  #29
ssoliman's Avatar
ssoliman
there was a video I saw, guy owned a business that rebuilds superchargers. he mentioned that with our SC the main issue was the seal leaking on the water pump side. then the gears on that side burn up. I notice, on mine, the water pump side of the case was dirty. like from the oil leaking out over time.
he didn't mention how he remedied the issue. guess thats the secret sauce
Old Oct 23, 2025 | 08:02 PM
  #30
ssoliman's Avatar
ssoliman
more work done today. some pics
Old Oct 25, 2025 | 08:57 AM
  #31
ssoliman's Avatar
ssoliman
more work yesterday, some pics:
Old Oct 25, 2025 | 08:58 AM
  #32
ssoliman's Avatar
ssoliman
rebuilding the axles now. Anyone know a fool proof way to identify a stock axle?
Old Oct 25, 2025 | 07:26 PM
  #33
ssoliman's Avatar
ssoliman
got the axles rebuilt today. some pics
Old Oct 26, 2025 | 08:48 AM
  #34
phone_cover
I kinda feel like I should have rebuilt mine instead of buying replacements. The passenger side on mine leaks where it goes into the transmission. I've replaced the seal twice. But my originals were turned in as cores, unfortunately.
Old Oct 26, 2025 | 10:21 AM
  #35
DaleR's Avatar
DaleR
I used this to reseal the endplates on mine.
Old Oct 27, 2025 | 10:10 AM
  #36
ssoliman's Avatar
ssoliman
mine are not all original either i dont think
the left one is unknown
the right is now half GKN and half original. the GKN half is from a left side axle, originally
Old Oct 27, 2025 | 10:11 AM
  #37
ssoliman's Avatar
ssoliman
thank you, Dale. i think i am going to do the same on the water pump side. the pulley side was air tight so i will prob leave it be
Old Oct 27, 2025 | 10:29 AM
  #38
mooser's Avatar
mooser
Good Job
Old Oct 28, 2025 | 08:38 AM
  #39
ssoliman's Avatar
ssoliman
thank you, mooser. lets see if it works when i get it all back together
Old Oct 29, 2025 | 07:20 AM
  #40
ssoliman's Avatar
ssoliman
***question***
what is the proper way to install the timing chain tensioner, compressed or extended?
Old Oct 29, 2025 | 08:13 AM
  #41
phone_cover
do it compressed so you can easily get the timing chain in place. then once it's all done, you can pop it open with a screwdriver or actual chain tensioner arm.
Old Oct 29, 2025 | 08:23 AM
  #42
ssoliman's Avatar
ssoliman
sorry did not included enough detail
the chain is in place. will not be doing the chain, tensioner rails, sprockets etc this round. the valve cover is not coming off this time and the chain cover is already back on.
compressed or uncompressed?
Old Oct 29, 2025 | 10:15 AM
  #43
LukasH's Avatar
LukasH
ModMini states compressed. You will get a short rattle at start up but once oil pressure is there, its gone. Should not take more than 3 seconds.
Old Oct 29, 2025 | 10:24 AM
  #44
Scoobaru2010's Avatar
Scoobaru2010
@ssoliman Compressed indeed, once you have it installed gently pry back on the tensioner to release it. Sometimes they wont release until startup as mention and you'll get a 3 second death rattle. Part of mod minis headgasket video i followed back last year, should be here about 14 mins in ->
Old Oct 29, 2025 | 11:40 AM
  #45
ssoliman's Avatar
ssoliman
thank you for the feedback, Gents. I did see that video.
TIS also says to install it compressed and then "ratchet it out with a lever". that would be from the top, if the valve cover were off (the valve cover is not off).
I can't help but think that it would be safer to install it in the extended position. That way i am sure that the chain will be in tension on first start
i'm i overthinking it?
Old Oct 30, 2025 | 11:41 AM
  #46
phone_cover
i think your risk with doing it expanded would be in trying to make sure you get the tensioner cover plug back in place properly. the risk with doing it compressed and letting the engine pop it out would be that the timing chain could skip a tooth before the slack comes out.
i think it would be less effort to retighten the plug than address a skipped tooth.
i installed mine with the oil pump removed. i was able to look at it both ways and spent a little time playing around with the two options. i don't think you really are going to create any problems for yourself doing it expanded. that's what i would do.
Old Oct 31, 2025 | 06:52 AM
  #47
ssoliman's Avatar
ssoliman
thats what I was thinking. still waiting on the new cap / bolt with crush washer. waiting on delivery but not sure yet what I will do.
seems like its accessible from the top. so I could always do it later when I have the valve cover off.
now I'm feeling like I should have pulled the valve cover and done the chain, sprockets, guides. How important is replacing the chain and sprocket as a maintenance item (not currently having any issues at ~160k miles)
trying to avoid scope creep on this round of work
Old Oct 31, 2025 | 06:55 AM
  #48
ssoliman's Avatar
ssoliman
got the oil filter housing, drive shafts, and lower engine support back in yesterday
Old Oct 31, 2025 | 06:57 AM
  #49
ssoliman's Avatar
ssoliman
the black grease from the busted driveshaft boots is EVERYWHERE. went through so many shop rages
Old Oct 31, 2025 | 05:54 PM
  #50
Here2Go's Avatar
Here2Go
NAM Community Team
​​​Well not much help but more of an admission to stupidity and guilt. I too spent an inordinate amount of time cleaning up all that grease from a torn inner axle boot while refurbishing my axles. After all that work only to discover, again, grease was everywhere after my first drive - I had forgotten to burp the inner passenger side axle boot. A mistake I'll soon never forget. A kindly tip from my own faux-pas...
Make sure you burp the boots.
