R50/53 Throttle body problems
Old Feb 15, 2024 | 02:46 AM
Shav0's Avatar
Shav0
Hello,
I am trying solve problem with my Mini R53 JCW.
After I start engine the P1225 or P0638 shows up, sometimes the engine has really low torque, sometimes just turn off, engine light on, limb mode etc...
I tried change throttle body (3 different pieces) and still after few starts same problem.
Connector looks ok, I cleaned it, clear TB, delete errors, adaptations was set, also I changed the ECU and battery, new filter. But still doesn't work. The harness is not the problem in my opinion, becouse this problem is allways only after start, or after few meters, never during ride.
Do you have any ideas how to solve it, or what can I check next?
I read some threads here, but nothing like this.
Thanks.
Old Feb 15, 2024 | 06:09 AM
JABowders's Avatar
JABowders
Veteran: Army
I would like to help but I don't have P1225 on my list. (no idea what it is). Have you checked the Throttle Pedal, remember it is a Drive by Wire connection. (connectors and pedal function)
Old Feb 15, 2024 | 06:31 AM
cooper48's Avatar
cooper48
As JA mentioned above P1225 doesn't show up in the Bentley manual. Looking at the first three of the code P1225, the P indicates powertrain. The 1 indicates Mini (rather than SAE). The first 2 indicates fuel injection. The 4th and 5th numbers (25) indicate individual circuits/components, in your case unidentified.
I would start with the fuel delivery system by checking the pressure at the fuel rail to determine if the fuel pump is faulty, then move to testing/replacing individual injectors. Here is a company that will clean/test your injectors for $12.50/each.
https://highperformanceinjectors.com...aning-services
You might also use the Freeze Frame facility on your code reader to help identify the problem.
Old Feb 19, 2024 | 03:09 AM
adriancl's Avatar
adriancl
Try to diagnose with INPA cable. is Mini BMW dedicated, will get the right fault codes.P1225 is not Mini specific fault code.
Fradow
Apr 11, 2023 07:48 AM
Ju1cE
Jul 5, 2021 08:33 AM
micromini234
Jun 7, 2016 02:35 PM
orfordbrits
May 28, 2011 09:36 AM
Fei
Jan 13, 2011 03:37 PM
