R50/53 Detailed removal of Steering Angle sensor
http://wtxmc.org/MiniCooperDocs/STEERING%20COLUMN.pdf
This is the most detail on removing plastic blister / steering column panels for the 2002 to 2006 Mini Cooper , when replacing or repairing Steering Angle sensor and precautions to follow…
A bulb has blown. This panel is illuminated by just two bulbs. When one fails, half of the panel no longer illuminates.
You will need:
You will need:
- Two replacement clear bulbs of type 509T. These are available from Halfords, who sell their own branded bulb and one by Bosch. I chose the Bosch bulb, which was fine but did not fit as nicely as the original Mini part. Why two bulbs? You're going to be spending hours doing this job, so you may as well replace both bulbs while you're there. Also, there could be a slight variation in brightness between the existing good bulb and the new one. These bulbs are around £2 each.
- Torx screwdrivers (T40 and T20)
- #2 Phillips screwdriver.
- A fairly wide flat-blade screwdriver.
- Small hands.
- Plenty of time and patience.
bbarlow641
May 20, 2024 11:45 AM
Tombstone
Oct 10, 2021 12:23 AM
