R50/53 k-swap kit out
Now imagine if it didn't leak any fluids for 150k+ miles, parts were cheap and ubiquitous and bolt-ons got you to 250+ in no time!
Now, imagine if there was anything that looked as good as an r53, sounded as good, was as easy to work on, or made you smile as much... I think the r53 engines are quite reliable, very robust, and capable of taking a lot more hp than they are delivered with. But, older cars are easy targets for frankensteining I suppose.
R53's are super easy to work on, and IMO - the *most* reliable of the MINI engines, but I will admit bias. There are a multiplicity of folks here with over a quarter million miles on the gen1 engines. This can't be about ease of working on, or about parts availability or cost - there is Allmag, Redline, and ebay - not to mention probably over 50k r53's in junkyards and pick n' pulls. This has to be about frankensteining and hot rodding. If that's what it's about, then by all means! I, personally, hate the noise that comes out the back end of pretty much every Honda I have ever heard (s2000 excepted).
BUT, the cost to swap in a Kseries into a Mini starts at 10k.
I have a hardtop S that I might ruin and swap in my 700hp kswap into when I jswap my other car. Cause, 700hp. But might wait until the Mini pops the motor.
Kseries is a FAR better platform than the BMW sourced engine.
I'd love to pick up an na mini over winter and begin a kswap..
people just arnt realizing $ for $ how much more power your going to get out the honda motor... the money and parts I've throw at this mini engine , had it been into a K series I'd be atleast in the 500hp range and yet just as if not more reliable too..
- $1500-$2000, engine w/ gearbox
- $500-$1000, engine harness
- $1000, ECU
- $500, clutch kit
- $500, header
- $500, tune
- $200, axles
- $350, mounts
- $100, shifter cables
- $150, shifter box
- $1000, miscellaneous. (fuel line adapters, clutch line adapters, cooling system adapters
- Optional: $2800 for RTP swap kit... (remove from above: mounts $350, axles $200, harness $500)
So, I was off, min of ~$6000, doing all the work yourself.
and they're correct lengths already , no cutting n rewelding ?
Quick / Rough estimates:
- $1000, ECU
- $500, clutch kit
- $500, header
- $500, tune
- $200, axles
- $350, mounts
- $150, shifter box
- $1000, ECU
- $500, clutch kit
- $500, header
- $500, tune
- $200, axles
- $350, mounts
- $150, shifter box
And yes, a $100 junk clutch kit on a resurfaced old flywheel would have you driving the car away.
Would I want that, after spending nearly +$5k to kswap my mini? No.
You could certainly do this all on a budget of less than $6k, but it'll require far more legwork (ie. scouring for sale ads for cheap used stuff) and for a far worse build.
mikehks
Jun 24, 2021 07:22 AM
Scelata
May 24, 2021 02:06 PM
mattkosem
Tires, Wheels, & Brakes
33
Sep 2, 2017 07:05 PM
