R50/53 P0340
Old Apr 22, 2022 | 07:19 PM
Yellowj's Avatar
Yellowj
P0340
Hello,
sort of new to the mini world. We bought our daughter a 2004 Cooper S. recently it quit while she was driving, turned over but no spark. OBD II SCAN says P0340. Put in a new cam position sensor and still no start/spark. Redid the scan and still throws the P0340?! Any help for a newbie is appreciated.
Old Apr 23, 2022 | 02:15 AM
minniedryver's Avatar
minniedryver
Once upon a time, I read that after replacing sensors you need to rest the ECU. Give this a try for a no cost next step:How to Reset the ECU:
  1. With the key in the ignition, but in the off position, press and hold down the odometer reset button with one hand.
  2. While holding the button down, switch the key in the ignition to position 1 (first click) with the other hand. The screen will have a number and the word “TEST”.
  3. Scroll through the numbers by pressing the odometer rest button, through to 19 and wait a moment. (Note: the number order is: 1,2,10,19)
  4. The message will say 19 "L i-off", flash to "L i-on", and back to "L i-off" again. When "log i-off" appears, press the odometer rest button again.
  5. You are now in the system. Scroll through to 21. TEST and wait a moment. 21.0 RESET will come up. Press the button once.
  6. Your gauges will now make some sounds and movements.
  7. Once the lights come back on start your car. You have now reset your ECU and your MINI is now ready to relearn the new mods and your driving style
Old Apr 23, 2022 | 06:27 AM
mrbean's Avatar
mrbean
Get your hands on a BMW/MINI specific scan tool. They often catch error codes that a generic OBDII scanner will miss.
Old Apr 23, 2022 | 08:17 AM
adriancl's Avatar
adriancl
Originally Posted by Yellowj
Hello,
P0340 is related to crankshaft sensor, not to camshaft sensor.Repalce crankshaft sensor and engine will start.
Old Apr 23, 2022 | 04:17 PM
Yellowj's Avatar
Yellowj
Ok, I used an OTC OBDII scanner and it said camshaft position sensor, did the ecu reset but no change. I’ll order a crankshaft sensor as suggested and track down a bmw scanner.
Old May 10, 2022 | 05:20 PM
Yellowj's Avatar
Yellowj
Ok. Frustrations grow. New camshaft sensor, new crankshaft sensor, new coil and wires. Reset the computer. Still no spark and no codes. If I had hair, I’d be pulling it out.
Old May 10, 2022 | 07:34 PM
cooper48's Avatar
cooper48
Check this link and you'll find useful info on P0340.
https://www.carparts.com/blog/code-p...%20the%20issue.
Old May 11, 2022 | 12:30 PM
adriancl's Avatar
adriancl
Check fuse F2 is 20A located in engine bay , this one is used for ignition coil crankshaft sensor and injectors .
Old May 13, 2022 | 09:08 AM
Yellowj's Avatar
Yellowj
Fuse is good, new spark plugs. I put an inline spark tester and still no spark. Tested the new coil with a multi meter and it’s good. I am at a total loss.
recap
new crank position sensor
new coil,wires and plugs
new battery
cleared codes
reset imobilizer
still no spark
Old May 13, 2022 | 06:21 PM
dmath's Avatar
dmath
Could it be a bad ground?
Old May 13, 2022 | 08:30 PM
Yellowj's Avatar
Yellowj
main grounds are good, I’ll have to start following the wires back from the coil…. The struggle is real 😵‍💫
Old May 14, 2022 | 06:34 AM
Mike87's Avatar
Mike87
I would check the mechanical timing of the engine (cam/crank) to make sure that your chain did not move/slip.
You said that it just quit while driving. That could be something mechanical. Go back to basics.
Pookie0412
May 18, 2021 08:05 PM
Bilo8792
Mar 29, 2021 02:23 PM
Minni help
Nov 30, 2019 10:40 AM
sparkyj
Jan 6, 2018 02:46 PM
miniturtle
Aug 17, 2008 01:19 PM
