R50/53 I have a chance to buy an LSD on Crushed r axle ?
Old Apr 11, 2022 | 01:20 PM
frankiev's Avatar
frankiev
I have an opportunity to buy an 04 LSD with 80k miles ,however the donor vehicle was crushed on the right front . Should I take the chance ?
Old Apr 11, 2022 | 05:14 PM
cooper48's Avatar
cooper48
The LSD is inside the transmission on the left side of your car. What are your concerns?
Old Apr 11, 2022 | 05:49 PM
frankiev's Avatar
frankiev
Yup . Stupid question on my part
Old Apr 11, 2022 | 05:51 PM
Da_Ghost's Avatar
Da_Ghost
I mean, not really. If the transmission looks fine, I don't think it will be an issue.
Old Apr 11, 2022 | 06:30 PM
frankiev's Avatar
frankiev
I guess what I was thinking was wether the tire was hit hard enough to jam the axle into the trans
Old Apr 11, 2022 | 07:08 PM
A383Wing's Avatar
A383Wing
there is a fairly solid stout carrier bearing support that bolts to the bottom of the block on the right side of the engine.....
Old Apr 11, 2022 | 08:42 PM
RB-MINI's Avatar
RB-MINI
Possible damage aside, how do you know it’s an LSD?
They weren’t available from the factory before ‘05. Of course the trans could have been swapped, or had an aftermarket LSD installed, but has the yard provided any good info or pics to know if it really is an LSD?
Old Apr 11, 2022 | 09:51 PM
AcidK1's Avatar
AcidK1
This the JCW car your getting the engine from?
Not a stupid question, I would ask the same. As said it's buried in the gearbox and the inner cv joint would have to break the side of the gearbox really to risk damage to it I think
Old Apr 12, 2022 | 03:35 AM
frankiev's Avatar
frankiev
I will verify it's a BKL code. Thanks to all
Old Apr 12, 2022 | 06:17 AM
frankiev's Avatar
frankiev
It turns out that it's not an LSD , however they have a other one from an 05 that had 144k on it.
From what I've found here on this forum these LSDs don't have clutches and don't wear out. Seems like a good deal for 450 but things aren't always what they seem. Any comments or advice welcome
Old Apr 12, 2022 | 07:34 AM
RB-MINI's Avatar
RB-MINI
The ‘05 is confirmed to be a BKL LSD?
Getting the code off of the transmission is always better, but I would run at least run the VIN to see what the original car came with. Any ‘05, ’06 R53 or ‘05 - ‘08 R52/Cabrio S would show option 2TA or S2TA depending on the format the decoder uses.
Old Apr 12, 2022 | 11:34 AM
frankiev's Avatar
frankiev
All the vin decoders I'm finding want $ . I call a dealer and was told it does have LSD .
Old Apr 12, 2022 | 11:53 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Try this one:
https://bimmer.work/
Old Apr 12, 2022 | 12:10 PM
frankiev's Avatar
frankiev
That worked . Definatly an LSD .
Old Apr 12, 2022 | 06:26 PM
frankiev's Avatar
frankiev
What's seals should I replace before I install it . Also it would be great if someone could recommend which gear oil to use.
Old Apr 12, 2022 | 07:16 PM
cooper48's Avatar
cooper48
Definitely change the rear engine seal while you have the trans out. Redline MTL SAE 75W80 API GL-4 gear oil is your best bet.
Old Apr 12, 2022 | 07:32 PM
A383Wing's Avatar
A383Wing
I used a Felpro rear main seal in my car, plus I used Quaker State full synthetic 75-90 gear oil along with one bottle of friction modifier for the LSD added to the trans for the LSD. Install the friction modifier first
Bryan
Old Apr 13, 2022 | 03:37 AM
frankiev's Avatar
frankiev
What about the input shaft seal on the diff Best to leave it ? I didn't think the lsd needed a feiction modifier . What did you use ?
I'll be swapping the clutch that i just installed 6 months ago from my old diff
Old Apr 13, 2022 | 03:49 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
If the LSD is gear based and not clutch based, no need for the friction modifier. I used Lucas gear oil in my transmission. Seems to work really well with the syncros.
Old Apr 13, 2022 | 09:51 AM
frankiev's Avatar
frankiev
Should I leave the input shaft seal alone or replace it . Also I'll be moving the Valeo clutch I just put in my current diff a short time ago, to the new diff . Can I reuse the guide tube or do I need a new one
Old Apr 13, 2022 | 09:54 AM
AcidK1's Avatar
AcidK1
I replaced all the seals on my box, 2 driveshafts seals and input seal. I kept the guide tube as it was in good condition and bearing slid easy. Small smear of grease on the tube to help the bearing is always good
jiggajaymz
14
Apr 19, 2006 11:47 AM
supercoopers
Feb 22, 2005 12:44 PM
