R50/53 the engine I just bought is a JCW !
Old Apr 9, 2022 | 04:44 PM
  #26
frankiev's Avatar
frankiev
I dont have any pics yet.
Old Apr 9, 2022 | 04:46 PM
  #27
frankiev's Avatar
frankiev
Originally Posted by BlwnAway
Because it's an '04 JCW, those were the 200HP rated cars, that were delivered stock and had the JCW kit installed by the dealer, the original owner probably just missed the 5 to 6 speed switch, esp if it was built in late '3 as an '04.
Well if it is a 5sp can I use my 6sp in place of it without too much misery. It may just be a miss print int the ad . I'll find out monday
Old Apr 9, 2022 | 04:57 PM
  #28
deepgrey's Avatar
deepgrey
Of course. People swap the early 5 speed Midlands in their R50s to the later 6 speed Getrags because the Midlands is famously fragile and has a tendency to grenade itself when faced with the whopping 115 hp of the base model.
Old Apr 9, 2022 | 08:11 PM
  #29
A383Wing's Avatar
A383Wing
5spd & 6spd differences are:
clutch, starter, axles, shift cables, trans mounts (I think)
There may be more differences.....
Which is why I asked earlier for pictures....if you can get some, post them up
Old Apr 10, 2022 | 12:34 AM
  #30
AcidK1's Avatar
AcidK1
Are youu sure someone hasn't added second hand jcw 'trim' to a standard engine? As said r53 didn't have the 5speed. Unless the car has been raced a lot as I have heard the midlands is far better for fast/hard driving, but weak inside. All you really need to do if you have the 6speed in yours already is swap the engines out (change clutch and inner cv joint seals and crank seal behind flywheel)
Old Apr 10, 2022 | 04:19 AM
  #31
frankiev's Avatar
frankiev
Thats seems like the most likely reason for the 5spd if indeed it is a 5spd . That leads me to another question . If they went to that extreme and swapped out the 6 for the 5spd then they probably changed the cam and probably have a custom tune as well .who know what else
Old Apr 10, 2022 | 06:06 AM
  #32
frankiev's Avatar
frankiev
Found some pics of the car
Old Apr 10, 2022 | 06:20 AM
  #33
frankiev's Avatar
frankiev
Quick vin check says 6spd trans so if it has a 5spd it was changed . I'm not sure what to think regarding other engine mods. If there's a bigger cam etc.
Old Apr 10, 2022 | 08:25 AM
  #34
RB-MINI's Avatar
RB-MINI
The pic resolution is bad, but from some of the parts and the large outmotoring decal, that car looks like it belonged to someone that was really into MINI’s
That looks like a factory JCW carbon spoiler, possible Team Dynamics wheels, bigger brakes (possibly JCW’s), possible JCW carbon hood scoop, hatch handle, and super rare mirror caps. It also looks like the front and rear JCW badges are still there. Lots of $$$ stuff if you can pull them yourself. If not, I don’t know/doubt if they would be careful enough to pull the stuff off without damaging them.
Is this place local to you?
Old Apr 10, 2022 | 09:30 AM
  #35
frankiev's Avatar
frankiev
Thanks for the info . It's a bit of a drive but doable . I'm having the engine shipped because the gas would cost almost as much as the shipping. I will ask about the parts you mentioned tomorrow.
By mirror caps you mean sideview mirors , corect ?
Im wondering if anything else was done to the engine
Old Apr 11, 2022 | 07:51 AM
  #36
frankiev's Avatar
frankiev
I just spoke to rhe yard . There sending me the SC, TB ,BPV,and the intake manifold / injectors . They're going to check compression when the engine is out and call me .
Old Apr 11, 2022 | 09:24 AM
  #37
frankiev's Avatar
frankiev
Bad news . They said cylinder 1 and 2 compression readings are 60 and 90
Old Apr 11, 2022 | 12:14 PM
  #38
frankiev's Avatar
frankiev
Turns out the car had a 6spd lsd which I'm working on acquiring. They want 450 for it
Old Apr 11, 2022 | 02:37 PM
  #39
RB-MINI's Avatar
RB-MINI
There was no Factory LSD option available from MINI before the MY ‘05 facelift. Research the codes to make sure, but I think the LSD gear boxes have the code BKL and the regular ones are BKD. Then I would check with the yard to see what gearbox they have before purchasing.
Old Apr 11, 2022 | 03:37 PM
  #40
A383Wing's Avatar
A383Wing
Originally Posted by RB-MINI
There was no Factory LSD option available from MINI before the MY ‘05 facelift. Research the codes to make sure, but I think the LSD gear boxes have the code BKL and the regular ones are BKD. .
Yes...factory LSD gearbox is tagged "BKL"
Bryan
Old Apr 11, 2022 | 03:42 PM
  #41
A383Wing's Avatar
A383Wing
could be rust build up on the valves & seats......my '06 JCW motor I got from wrecking yard had low compression in one cylinder, I was about to call the yard back when I decided to put some oil in the cylinder and keep doing the compression test on the back of my truck tail gate.....every time I ran another compression test, the numbers keep coming up......once they were all equal around the 160psi range, I decided the engine was a good one. I also had a mechanical oil pressure gauge installed and had 25lbs at cranking speed
Bryan
RhinoEngler
Jun 18, 2020 05:36 PM
crispins
Feb 1, 2018 12:29 PM
carswithmuscles
Oct 20, 2014 06:20 PM
coopcoupe
May 29, 2012 12:34 AM
DigitalPhoenix
14
Oct 3, 2011 08:42 AM
