R50/53 Leaky from thermostat housing...common?
Old Mar 14, 2022 | 05:37 PM
IQRaceworks's Avatar
IQRaceworks
I've had a coolant leak on my 03' R53 for the last couple of weeks, and decided to dive into it tonight. As far as I can tell, it looked like the leak was coming out of the thermostat housing...what a pain to get to that thing! The housing and gasket looks fine, but I'm guessing that after 19 years and 195K miles.....it's done pretty good.
I didn't see anything else that looked wet, so I'm assuming that's where the leak was coming from. I'm assuming I should replace the entire thermostat housing along with the thermostat and gasket?
I just want to make sure I'm not missing anything so I don't have to get in there again and do it all over.
Thanks!
Old Mar 14, 2022 | 05:46 PM
ChiefM's Avatar
ChiefM
It is a common leak area. Yes replace the housing and the thermostat.
Old Mar 15, 2022 | 05:28 AM
dmath's Avatar
dmath
Watch a Youtube video on replacing the thermostat housing on a Gen 2 Mini. It will make you feel MUCH better about the Gen 1 job.
Old Mar 15, 2022 | 06:24 AM
Thomas Burdek's Avatar
Thomas Burdek
Just changed mine, go with an aluminum housing. Will outlive the car.
Old Mar 15, 2022 | 09:15 AM
Yep
DIY: https://www.northamericanmotoring.co...rmostat-430896
Most people just go with the metal one.
https://www.ecstuning.com/Search/Sit...h/11537596787/
Old Mar 15, 2022 | 09:18 AM
Thomas Burdek
Hey @ECSTuning . Ordered two kits. One for my dad and one for me. The first thermostat I put in my car started to not close after 2 days. What should i do. I put the other one in and it works just fine.
Old Mar 15, 2022 | 09:29 AM
If you get a thermostat that sticks, check it first to make sure it was stuck,. And not something else in the cooling system, like junk or a piece of gasket
Boiling hot water and throw the thermostat in it and see if it moves. Then pull it out into cold water, If it still does not work contact our customer service. Let them know and they can get a new one out to you.
Every one in a while we might see one that sticks. Even on the wahler factory MINI Genuine ones.
Manny Fedora
Jan 24, 2020 04:59 PM
Solute
Jun 24, 2015 08:17 AM
supereek
Oct 13, 2012 10:09 PM
Randy-ole-ran
Feb 16, 2011 01:39 PM
ultraclyde
Mar 20, 2010 08:42 AM
