Thermostat Housing Leak
Old Dec 20, 2019 | 05:24 AM
Manny Fedora's Avatar
Manny Fedora
Hi all and happy holidays!
So a month ago I took my 2013 Cooper S for an oil change and in the process they accidentally broke the hose coming out of the coolant reservoir, which they then replaced at no cost.
Fast forward now and my Thermostat Housing is leaking and causing my car to overheat.
I am wondering if the Thermostat Housing leak could be the result of a botched job while replacing the coolant reservoir hose.
Any advice is highly appreciated.
Cheers!
Old Dec 20, 2019 | 05:48 AM
MiniToBe's Avatar
MiniToBe
Anything is possible. can you confirm where the leak is coming from? could they have forgotten to clamp the hose?
Old Dec 20, 2019 | 06:42 AM
Manny Fedora
Thanks for reply mate!
I just know it's from the Thermostat Housing from what I've gather, not exactly sure where though.
Old Dec 20, 2019 | 07:18 AM
Might have been a botch job or the gasket was turned and not seated, bolts worked loose? I would get a closer look at it. Use you cell phone camera and rear down under and see what it is.
Old Dec 20, 2019 | 12:13 PM
nola mike's Avatar
nola mike
Good luck getting them to admit to anything after a month in a 6 year old car known for coolant leaks...
Old Jan 3, 2020 | 07:02 AM
Did you ever find out what it was?
Old Jan 24, 2020 | 04:59 PM
Rich B.'s Avatar
Rich B.
Fluids flow downhill. Even a small leak up at the expansion tank fitting could appear as a thermostat housing leak. Check closely. Our cars have very little slack in the hose connected to the bottom of the expansion tank which makes moving the tank for access to the oil filter a very precarious exercise. On my car I change the oil filter totally by feel. It's not fun, but necessary.
Solute
Jun 24, 2015 08:17 AM
supereek
Oct 13, 2012 10:09 PM
donjulio
Apr 13, 2011 11:20 AM
Fatherdeth
Mar 29, 2010 05:47 AM
crichardson
Jan 3, 2010 10:38 AM
