R52 We're does this 4 pin plug go on r52 automatic
Old Nov 30, 2021 | 07:50 AM
Rich226's Avatar
Rich226
Can anyone please help me find we're this cable goes on a automatic 2005 r52 it's off the main engine harness
Old Nov 30, 2021 | 08:18 AM
ChiefM's Avatar
ChiefM
Power steering?
Old Nov 30, 2021 | 08:23 AM
Rich226's Avatar
Rich226
Thanks for the reply
Hey no it's not off the power steering pump and its not the knock sensor or gearbox so I'm lost as to we're it could go
Old Nov 30, 2021 | 10:05 AM
ChiefM's Avatar
ChiefM
I have a stick and I have not seen a plug like that on my Mini.
Old Nov 30, 2021 | 10:25 AM
Rich226's Avatar
Rich226
Hi
Thanks for your reply,you won't see this on your stuck car as this is for automatic only and the 2 looms are different.
Old Nov 30, 2021 | 11:23 AM
Lennon's Avatar
Lennon
I responded to your other thread. That appears to be the connector to the "Start Inhibit Switch" on the transmission (CVT). Located on the back of the transmission, just above the pan. Number 4 on the diagram.
Old Nov 30, 2021 | 12:25 PM
Rich226's Avatar
Rich226
Thanks 😊
Hi thanks very much for your time and help you are the man
Old Nov 30, 2021 | 01:56 PM
Rich226's Avatar
Rich226
Hi sorry to say it's not the one from the gearbox the one one the gearbox is a 2 pin the one I have is a 4 pin plug
Old Nov 30, 2021 | 02:19 PM
Lennon's Avatar
Lennon
Are you sure you looked at the switch / sensor I was referring to? I know that's a 4 pin connector. It even shows the connector on the parts diagram titled "4 pole connector". The other connector on top of the transmission is different.
The connector is on the main engine harness, on the branch with the oil pressure switch and starter solenoid wires, it just keeps extending and reaches that switch on the transmission.
Here is a pic of the Start Inhibit Switch. You can see it has 4 pins.
Old Nov 30, 2021 | 02:24 PM
Rich226's Avatar
Rich226
You must be 100% correct and I can't see it but I trust your judgement and will take another look thanks again very much my friend you are a life saver
Old Nov 30, 2021 | 03:13 PM
Lennon's Avatar
Lennon
Try to look from under the car, or in from the left side wheel housing, and you should see it.
It is possible I am mistaken, but based off your description and pics that should be it.
Rich226
Nov 30, 2021 10:56 AM
sarvman18
Apr 29, 2018 05:25 PM
thatminicarguy
Jul 18, 2017 12:47 PM
Jonathan66
Oct 17, 2014 10:53 AM
