R50/53 Knocking issue
Old Nov 12, 2021 | 08:08 PM
Brandon Fluharty's Avatar
Brandon Fluharty
Knocking issue
I have a issue where I’m hearing a mild knock coming from mid engine to bottom by the oil pan I have a single mass flywheel but pressing the clutch doesn’t make the noise stop and the knock follows the rpm and I can’t tell where exactly it’s coming from
Old Nov 12, 2021 | 08:14 PM
DFTR's Avatar
DFTR
Balancer?
Old Nov 12, 2021 | 08:35 PM
Brandon Fluharty
Originally Posted by DFTR
Balancer?
It’s been replaced with a 2% Ati pulley
Old Nov 12, 2021 | 08:39 PM
DFTR's Avatar
DFTR
Bummer. I was trying to be optimistic. May be worth a peek though. An oil sample is $20 and will spot a bearing quick.
Old Nov 12, 2021 | 08:40 PM
Brandon Fluharty
I have been using 5w30 synthetic blend of that had anything to do with it only because this is a fully built motor but if I need to I will switch oil and do a flush asap
Old Nov 12, 2021 | 08:41 PM
Brandon Fluharty
where would I shop it to I’m out in south Texas as of now
Old Nov 12, 2021 | 08:44 PM
DFTR's Avatar
DFTR
Dude let's hold onto hope a bit longer. Others will be along with ideas. Just saying that a sample can rule out, or in a bearing.
Old Nov 12, 2021 | 08:47 PM
Brandon Fluharty
I agree lol I’ve just never had to send oil samples so idk where to ship it but I mean it runs fine and doesn’t sound like devastating rod knock noise it just sounds off if that makes sense
Old Nov 12, 2021 | 08:52 PM
DFTR's Avatar
DFTR
My lab i use is in fl. Costs me $18 plus shipping. 24 hours results. Lots of good labs in TX, ms and la.
I use motorcheck. There's better labs closer to you. I only suggest this as you use the word knock. Not rattle, click, grind or squeak. If you need help pm me. No problem. And I hope others have better ideas.
Old Nov 12, 2021 | 08:59 PM
Brandon Fluharty
It’s dark but towards the end I had the phone at the bottom of the motor pointed towards the oil pan when you could clearly hear the “knock” at least that’s what I’m thinking it is
Old Nov 12, 2021 | 10:34 PM
JoshuaM's Avatar
JoshuaM
I could just be missing it but i'm not hearing a knock in that clip.
Old Nov 13, 2021 | 05:10 AM
DFTR's Avatar
DFTR
I cant hear anything either but my speakers suck.
Old Nov 13, 2021 | 06:05 AM
ssoliman's Avatar
ssoliman
I can’t hear much from the video. Towards the end I hear a clicking? That could be a number of things I’d guess
https://www.blackstone-labs.com
Old Nov 21, 2021 | 07:28 PM
Brandon Fluharty
So I’ve done some work since the last post what I’ve found is one of the plastic guides holding the rocker arms in place had cracked in half and failed but I also went to check the bearings and they all looked fine for how I treat the motor no oil starvation or anything and none are spun but even after fixing the plastic guide it’s still ticking/knocking when it’s warm
leeuwen
May 8, 2015 10:29 AM
kingblackfoot
Apr 8, 2013 07:59 PM
silversmoke06
Apr 2, 2008 04:54 PM
mikem53
Sep 13, 2006 02:43 PM
