R50/53 Oil filter socket size
Old Sep 6, 2021 | 12:27 PM
ChiefM's Avatar
ChiefM
I have been trying to change the oil filter in my 2003 R50. I don't know who pull the cap on last but I can't get the darn thing loose. What is the size of the nut on top of the filter housing?
Thanks!!
Old Sep 6, 2021 | 12:58 PM
BlwnAway's Avatar
BlwnAway
36mm
Old Sep 6, 2021 | 01:44 PM
ChiefM's Avatar
ChiefM
Thank you so much kind sir!!
I think I have that size wrench in my tool box at work but I am buying a low profile socket. Someone really tightened this thing down.
Old Sep 6, 2021 | 03:23 PM
BlwnAway's Avatar
BlwnAway
They tend to do that naturally.
Quite often you may need a breaker bar or extension on your ratchet, to get the initial loosening done.
Old Sep 6, 2021 | 07:21 PM
dmath's Avatar
dmath
In my limited experience, the cap is stiff even once loosened. Always makes me a little nervous.
Racingguy04's Avatar
Racingguy04
I've been changing the oil on these cars since 2006 (once the warranty on my 03 ran out) the best tools I've found are a 3/8 inch drive shallow 36mm socket and a long handle ratchet. Like this one. https://www.lowes.com/pd/Kobalt-36-T...atchet/3381184 Sometimes I'll switch to a short ratchet once it's loose, but usually I just take it off with the long ratchet.
Of course it helps if some one didn't crank it super tight when they installed it, and making sure that you lube the o-ring before you install it is important too.
Old Sep 6, 2021 | 07:46 PM
bump32's Avatar
bump32
I bought this after struggling the first time. This shallow socket makes it much more manageable.
https://www.outmotoring.com/3-8-driv...mm-socket.html
Be careful when putting the housing back on not to cross thread it.
Old Sep 7, 2021 | 12:34 AM
ChiefM's Avatar
ChiefM
Thanks guys!
I ordered a 6 point socket and I have a flex head ratchet in my tool box at work. It was Friday of a 3 day weekend and changing the oil filter was not on my mind.
streqicity
Feb 14, 2017 01:24 PM
GregO
Jul 23, 2010 10:33 PM
ryansoxfan
Jan 6, 2008 08:45 AM
RKMaroon
Jan 21, 2003 06:15 PM
Bmuelle
Oct 13, 2002 06:52 PM
