R50/53 Brake in oil
Old Aug 22, 2021 | 06:02 AM
Brandon Fluharty's Avatar
Brandon Fluharty
Brake in oil
My machinist told me to use valvoline vr1 20w30 and I just want to make sure that the engine can handle a thick oil like that for 500 miles
Old Aug 22, 2021 | 09:51 AM
mrbean's Avatar
mrbean
NO!
VR1 has a high zinc content which can dramatically shorten the life of you catalytic converter.
Use a MINI approved oil and change it after 500-1000 miles (or however long you think the break in will take).
Old Aug 22, 2021 | 10:00 AM
Brandon Fluharty
Originally Posted by mrbean
NO!
I don’t have cats…..🤣🤣🤣🤣 it’s a race motor and the exhaust is straight piped so I’m not worried about that I’m more worried about engine life than my cats
Old Aug 22, 2021 | 10:24 AM
BlwnAway's Avatar
BlwnAway
If you prefer, just find a high zinc content break in oil with a lower cold start viscosity spec. (10w30 or even 5w30) as long as it has a high zinc content for your break in period.
​​​​​​But honestly, the 20w viscosity spec shouldn't be a problem as long as your still in warm weather (above 70° or so), esp. with the extra zinc. Once the oil is above 110° the cold start spec goes out the window anyway.
​​​​​But do what you're comfortable with.
Old Aug 22, 2021 | 10:35 AM
Brandon Fluharty
awesome then I’ll go ahead and run it with the vr1 for 500 miles I live in south Texas anyways so the lowest we get is like 50 degrees Fahrenheit so that won’t be a problem but thank you for the reassurance
Old Aug 22, 2021 | 11:01 AM
BlwnAway's Avatar
BlwnAway
South Texas...
No problem at all then.
greasypeanut
Apr 17, 2012 06:41 PM
twlai
Nov 16, 2011 08:45 AM
MIN 18
Aug 2, 2007 08:33 AM
