R50/53 Hello question about ABS
Old Jul 21, 2020 | 11:52 AM
optikon's Avatar
optikon
Hello
I am from Serbia, my English is not so good so i will try to explain my problem. I have MINI one PARK LANE 2005 and my car have those simptoms:
1. Rumbling noise from the front wheels.
First my thought was old tires + RUN FLAT's
But ...
2. Now, i have trifecta on my dash from time to time.
What that means, i start the car my lights are on, after few meters light go off, i only have worn brake pads light on the dash (bad sensor i know). But, during the drive, (mainly city drive), on stand stil when press my brake i feel gentle vibration, and clicking noise from ABS module position. When i lift my foot off, it stops but after few meters my trifecta lights go on. I presume that my wheel bearing is on it's way.
3. Also, when i wash my car, when i pour water on the vents above ABS module, i have trifecta efect, also my temp gauge go up, check engine light go on, my RPM gauge stop working and reset all data of the trip, fuel usage etc ...
So, a lot of problems for such a small car ...
Old Jul 21, 2020 | 02:39 PM
cooper48's Avatar
cooper48
Rumble from the front wheels is most likely your hub bearings going bad. And by the way, your English is not bad.
Old Jul 21, 2020 | 03:31 PM
MVPeters's Avatar
MVPeters
re 3: - - I would check the electrical plugs & sockets, especially near the ABS unit. Use electronic switch cleaner.
Corrosion can cause some strange 'errors' that are not real.
gkp
Jul 9, 2019 06:20 AM
sull1102
Jul 12, 2016 09:34 PM
2009MiniS
Jun 17, 2015 06:56 PM
Sabes
Apr 29, 2012 09:24 PM
Charlie Croker
Apr 17, 2008 09:55 PM
