R50/53 Headlights flash when I turn key on.
Old Jun 3, 2019 | 09:58 PM
Richard Mendoza's Avatar
Richard Mendoza
When I turn my key to the on position my headlights flash a few times then they stop. This only happens when I turn the key on. This started happening after I changed my bulbs. I think I was supposed to unplug the battery before I changed the bulbs. Anybody know how to fix this? I tried resetting ECU and unplugging the battery but no luck. Please help
Old Jun 4, 2019 | 12:03 AM
MVPeters's Avatar
MVPeters
I think you've installed LED bulbs. The flashing is caused by the power-on bulb check. It's programmable $$$ so turning it off might stop the flashing.
Do you see an improvement when driving at night?
I'd install a decent set of Philips or Sylvania bulbs.
Old Jun 4, 2019 | 11:12 AM
Richard Mendoza
Yeah I installed led bulbs. They work great. It's just the flashing every time I start the car. How do I program it??
Old Jun 4, 2019 | 12:44 PM
MVPeters's Avatar
MVPeters
Dealer only programming, I believe, though some independent shops might possibly have the right equipment.
Or you can install resistors across the bulb wiring - try eBay - you need high rated ones for headlight bulbs, not the ones for directionals.
Old Jun 4, 2019 | 04:55 PM
Richard Mendoza
Aw crap.. I live in Hawaii and they charge an arm and a leg to even look at european cars lol. Not sure if the resistor will make a difference but I'll try it. Thanks!
Old Jun 4, 2019 | 05:27 PM
rkw's Avatar
rkw
1st generation MINI never had LED options. There is no programming available.
Old Jun 4, 2019 | 06:38 PM
MVPeters's Avatar
MVPeters
rkw
I have an early 2002 r53 with no options whatsoever - no Chrono, just a tach above the steering wheel & the big central speedo. All the warning lights are accounted for.
Where do you think a defective bulb warning would be displayed?
At start-up, the car runs a bulb check (causing LED bulbs to flicker) BUT, being a basic dashboard, there's nowhere to display a defective bulb warning.
Surely just turning the bulb-check option OFF should prevent the flickering.
Any ideas?
Old Jun 4, 2019 | 08:41 PM
Richard Mendoza
rkw
Any ideas?
That's what I was thinking. But i couldn't find any info on how to turn it off.
Old Jun 4, 2019 | 09:53 PM
alconk's Avatar
alconk
I have installed the V4 LEDs for my high beams and they do the same thing. I have even installed CanBus cancelled but they still blink at startup. Just have to live with it.
Old Jun 4, 2019 | 11:31 PM
Richard Mendoza
That sucks...
Old Jun 5, 2019 | 08:20 AM
alconk's Avatar
alconk
That sucks...
I agree!
Old Jun 5, 2019 | 09:45 AM
rkw's Avatar
rkw
None of the R50/R53 dashboards have a bulb warning. I think the flicker comes from a general electrical check of all circuits, not a specific "bulb check".
If you want to eliminate the flicker, the only workaround is to add a load resistor in parallel. The R50/R53 are too old and simply weren't designed for LED bulbs.
Old Jun 5, 2019 | 10:18 AM
Richard Mendoza
If you want to eliminate the flicker, the only workaround is to add a load resistor inline. The R50/R53 are too old and simply weren't designed for LED bulbs.
I'm not familiar with resistors. What kind should I use? What brand and what size? I can just add it anywhere along the wires to the light? Along the positive or negative?
Old Jun 5, 2019 | 10:19 AM
MVPeters's Avatar
MVPeters
N..... general electrical check of all circuits, not a specific "bulb check"...... .
rkw
Interesting,
I wasn't aware of that. So what happens if the 'all circuits' check finds a fault? - there's still nowhere to display it! Does it generate a code or CEL light?
I presume that if the 'all circuits' check were switched off (assuming that's possible), there might be some impact on performance - right? Limp mode?
Old Jun 5, 2019 | 10:59 AM
rkw's Avatar
rkw
I suggest you go to LED vendors (such as this or this) and look at their prepackaged bundles.
Javskies
Oct 20, 2017 06:14 AM
Devilpou
Mar 30, 2016 05:40 AM
brickren
Sep 30, 2012 09:02 AM
Axion
Factory JCW Talk (2009+)
Nov 27, 2011 05:15 PM
robino
Jan 25, 2007 03:08 PM
