R50/53 EML Problems
Old May 21, 2019 | 04:56 PM
Parkerlc's Avatar
Parkerlc
EML Problems
Other night I did a supercharger pulley reduction on my R53 and the next morning my EML light flashed on any idea of what might be happening? Should I take it to a shop and get them to run a diagnostics check on it.
Old May 22, 2019 | 07:51 AM
JABowders's Avatar
JABowders
Veteran: Army
EML is normally related to a fuel/air mix reading or oxygen sensor reading, or even a loose fuel cap.
Since you just did a pulley you added more fuel/air, it might blink from time to time until your adaptives adjust to the new mix ratio.
I would ignore it unless it comes on solid, but if you have a code reader you might want to check just to see what is popping the light.
Best of luck.
Motor On!
Old May 27, 2019 | 08:22 PM
Parkerlc's Avatar
Parkerlc
Best of luck.
Motor On!
Found out it was a code, #P1498 seems to be the inlet duct assembly. I think it may of cracked, one of the sensors broke or one of the wire broke off which is a common thing that happens, been doing some research.
WiscoR53
Jul 19, 2017 02:12 PM
Amytheallen
R55 :: Clubman Talk (2008+)
Aug 18, 2012 08:52 PM
Autoxser1975
Jun 12, 2011 02:27 AM
batticus
Aug 21, 2002 07:37 PM
