R50/53 Brake question
Old Apr 24, 2019 | 10:07 PM
speedman's Avatar
speedman
Brake question
Has anyone done a caliper swap using aluminum 4 piston calipers from another vehicle. If so what type were the calipers and did you have to make adapters?
Old Apr 24, 2019 | 10:18 PM
co0p3r's Avatar
co0p3r
Closest I have seen done is the BMW 135 brakes (which are the same as GP2 brakes) swapped to an R53.
I would think that if there have been other BMW swap kits something may match up for the MINI as the MINI brakes are all source right from the BMW parts bins.
I will tell you that the Wilwood Kit is a great option at a reasonable price and no headaches.
Old Apr 25, 2019 | 06:32 AM
speedman's Avatar
speedman
I thought I read a post that said you could use Cadillac CTSV coupe calipers
Old Apr 25, 2019 | 01:49 PM
R534life's Avatar
R534life
Might be worth checking out the 4th gen Miata Calipers. They come with Brembo's in some of the trim packages and the wheel bolt pattern is the same as a mini.
Old Apr 27, 2019 | 03:46 AM
speedman's Avatar
speedman
Thanks for the info. I will check it out
Old May 3, 2019 | 11:29 AM
toddtce's Avatar
toddtce
Seems like a lot of futzing around when you can do a complete front BBK for under $900. And know it was intended specifically for the car, will be lighter than any one piece rotor set up, comes with ss flex lines and has a host of easy fit pad options.
But I admit to being a bit biased.
pancakex
Jul 31, 2006 02:59 PM
Arly
Tires, Wheels, & Brakes
Jun 8, 2006 06:39 AM
MiniPilo
Oct 14, 2004 06:03 PM
rory
May 23, 2003 08:07 AM
