R50/53 Extra Alternator cable?
Old Apr 23, 2019 | 02:32 PM
Aldensolis's Avatar
Aldensolis
Hi guys,
so im about to do a coolant flush when i see a red cable coming out of the cables of my alternator. Now it seemed like it was taped across the fans leading upwards towards the fuse box but its actually just sitting there. Like its been disconnected.
And for the past couple of months I cannot get any readings from my obd connections.
Iv’e taken the mini to several mechanics and they all couldn’t figure it out.
So my question here is, does that red cable go somewhere?
Old Apr 23, 2019 | 04:20 PM
Tgriffithjr's Avatar
Tgriffithjr
Have you tried tracing it to its source?
Old Apr 23, 2019 | 05:00 PM
Aldensolis's Avatar
Aldensolis
[QUOTE=Tgriffithjr;4465297]Have you tried tracing it to its source?[/QUOTE
Yeah it looks like its just tapped into the white and green cable.
Old Apr 23, 2019 | 05:19 PM
A383Wing's Avatar
A383Wing
That red wire is not stock....remove it and re-tape the wires at the alternator.....
As far as your issue with the OBD II connector not giving you any data.....check your fuses, check your connector under the dash for bent or missing pins
Bryan
Old Apr 23, 2019 | 05:24 PM
Aldensolis's Avatar
Aldensolis
Will do, I’ll keep you guys updated. Thanks!
Old Apr 23, 2019 | 05:57 PM
Aldensolis's Avatar
Aldensolis
Update
so i removed and taped the cable up, checked for any blown fuses and they all were good :/
any ideas?
Tia.
Old Apr 23, 2019 | 08:43 PM
BlwnAway's Avatar
BlwnAway
I'm guessing that is where someone tapped for a volt gauge or something similar.
Papote
Aug 15, 2016 05:24 AM
FIZGIG
Electrical
Nov 3, 2013 11:31 AM
owl
Apr 8, 2009 05:06 PM
prof330i
11
Jan 18, 2007 12:10 PM
