R50/53 Xenon lense removal for R53
Old Apr 7, 2019 | 10:24 AM
Tombstone's Avatar
Tombstone
Does anyone know how to remove the a Xenon headlight lense on a R53 MIni Cooper ,because I want to get behind the lense to detail headlight plus remove the moisture streaks? Thanks...
Old Apr 7, 2019 | 10:37 AM
Jtrem's Avatar
Jtrem
Originally Posted by Tombstone
Does anyone know how to remove the actual Xenon headlight lense on a R53 MIni Cooper ,because I want to get behind the lense to detail headlight plus remove the moisture streaks? Thanks...
Around the outside of the lens you’ll see some black glue. Carefully heat it and push a flat blade screwdriver in.
Work your way around heating and prying until the lens separates from the housing.
Careful you don’t apply too much heat.
Putting it back together can be a pain to line up, so take your time.
Old Apr 7, 2019 | 12:14 PM
Tombstone's Avatar
Tombstone
Do you use a heat gun or oven to heat the Xenon unit ? Thanks...
Old Apr 7, 2019 | 01:46 PM
Jtrem's Avatar
Jtrem
I used a heat gun. Making sure not to get to close to distort anything.
Old Apr 7, 2019 | 03:43 PM
Tombstone's Avatar
Tombstone
Thanks again for the tip on the removal process. Regards...
Old Apr 7, 2019 | 08:19 PM
BlwnAway's Avatar
BlwnAway
If you get hung up, there are some tips in this thread:
https://www.northamericanmotoring.co...od-how-to.html
And while the thread mentions oven heating, I too have used a heat gun every time I've opened mine.
chows4us
MINI Camera and Video
25
Nov 15, 2006 04:17 PM
princeofwaldo
Sep 12, 2006 07:35 PM
E1Designs
Mar 10, 2005 08:00 AM
4GAZM
Apr 16, 2004 10:45 PM
REITT
Jan 29, 2003 04:56 AM
