R50/53 What is this knocking/rattling?
Old Mar 30, 2019 | 07:18 PM
meanmini135's Avatar
meanmini135
Sounds like its coming from the engine/supercharger. It used to be much louder when my oil was low, it quieted down since adding a quart.
YouTube video:
https://m.youtube.com/watch?v=SLDBt8CHjiA
Or search "knocking/rattle r53 mini" in posted today
Old Mar 31, 2019 | 05:47 AM
Tgriffithjr's Avatar
Tgriffithjr
Sounds like possibly timing chain tensioner.
Old Mar 31, 2019 | 07:58 PM
meanmini135
Is there any way I can fix it myself? I have tools but I can't really afford a mechanic at the moment
Old Apr 1, 2019 | 04:09 AM
Tgriffithjr
Yes it’s not that bad. But I’d wait for another opinion before jumping in. Someone here will chime in.
Old Apr 1, 2019 | 05:26 AM
cooper48's Avatar
cooper48
+1 on the tensioner replacement. That's certainly the least expensive repair associated with this type of sound. Access is a bit tight but look up ModMini on YouTube and you'll find a repair video. If that doesn't fix it, then your next step would be timing chain guides and/or chain.
Old Apr 1, 2019 | 06:10 AM
Fastlane's Avatar
Fastlane
+1 on the timing chain tensioner as a possible culprit. When mine started to go, it would only rattle when starting warm (i.e. when I would drive, park for a while, and then restart). Replacement is fairly easy and the part is cheap.
Now that said.....something else to check.....does the rattle go away when you press the clutch pedal in? It sounds a lot like a rattling clutch also. Hard to diagnose sounds in general, but especially via video.
good luck.
Old Apr 1, 2019 | 09:29 AM
meanmini135
I know for sure it's not the clutch. The sound continues even when I press the clutch in
FinalPhaze
Sep 11, 2004 03:34 AM
theWrkncacnter
Jun 16, 2004 10:26 AM
ABTsportsline
Apr 5, 2004 09:24 PM
Bluegarvis
May 27, 2003 03:06 PM
DavidR.
May 5, 2003 10:29 AM
