R50/53 mullicated oil drain plug
Old May 6, 2019 | 04:10 AM
  #51
r53-06m6's Avatar
r53-06m6
Originally Posted by ItsmeWayne
I'll tell you this, I have removed several of these "frozen" oil plugs, but I found all of them the flat gasket area was the thing that was freezing them, from coming out. I will admit that yours is butchered more than any I have tried to remove, but maybe if you use a dremel tool to grind away the flat part of the plug, it may just come out easy. I have never had to change a pan, in the dozen or so, I have done with Minis'. Hope you have success!
It is already ground flat. Starting to leak oil now. No luck though. Oil pan already ordered.
Old May 6, 2019 | 04:14 AM
  #52
r53-06m6's Avatar
r53-06m6
Originally Posted by Alpha Motoring
Weld a nut onto it and take it off. If you can’t weld take it to an exhaust shop and have them weld it on. It’ll be way cheaper than destroying your oil pan.
The thought had crossed my mind. I can weld ok, but wasn't sure how to weld a nut now that it is ground flat. How would I keep the nut held there to weld? Also, I am a bit concerned about a fire hazard in that area.
I am still willing to bet that I'd break the weld sooner than I'd be able to get this lose.
Either way, oil pan on the way. I'd rather avoid changing the pan but the pan was cheap. Welders always seem to stick it to me.
Old May 6, 2019 | 04:19 AM
  #53
r53-06m6's Avatar
r53-06m6
Originally Posted by njaremka
Use he correct wrench and do NOT over tighten. Snug it up just enough so there are no leaks, and your good to go. No need to crank it down like a gorilla.
Uhmmm, I wasn't the one who did this. I have changed oil hundreds of times on scores of cars and never had this issue.
Old May 6, 2019 | 05:02 AM
  #54
JAB 67's Avatar
JAB 67
Have you ordered a Fumoto yet?
Old May 6, 2019 | 05:04 AM
  #55
r53-06m6's Avatar
r53-06m6
No, I already have a magnetic drain plug that I intend to use.
Old May 6, 2019 | 09:51 AM
  #56
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
May I suggest a method that would not require changing out the pan? Just grind off that protruding piece, then get a very sharp drill bit, say 3/8 inch in dia. Use a center punch so as to be in the center of the bad drain plug. Coat your drill bit flukes with wheel bearing grease so as to catch the chips and drill a hole in the bad drain plug. Then use an "EasyOut" and back out the drain plug. You may not even need to drill all the way through the drain plug to get a sufficient "bite" with the "EasyOut". Certainly worth a try vs. dropping and replacing the oil pan.
Old May 6, 2019 | 09:55 AM
  #57
CRC's Avatar
CRC
^^^^ This is a good idea if you do not go too big with the drilled hole, and the easy out. If you do, hammering the easy out into the hole can actually make the bolt/plug/screw/etc expand and grip even tighter on the threads.
Old May 6, 2019 | 10:07 AM
  #58
r53-06m6's Avatar
r53-06m6
Thanks on the Easy-Out idea, but I ground off that piece already then tried Easy Outs earlier on in the thread starting with Easy Out sizes 1, then 2, then 3, then 4. :(
However, you are the first to give me an idea on how to go completely through that drain plug potentially. At some point, it started taking all year to go through the plug and the drill bit said get lost.
https://s46.photobucket.com/user/jj2...zgakh.jpg.html][/URL]
Old May 6, 2019 | 05:31 PM
  #59
NC TRACKRAT
Veteran: Navy
Bummer! Did the drill bit snap off in the hole? If not, get a better drill and use a variable speed drill. Take it slowly. Heat build-up is the enemy. Keep the drill flutes covered in grease and clean off chips periodically until you break through. The flow of oil should wash out any possible remaining chips. We're with you in spirit!
Old May 6, 2019 | 05:45 PM
  #60
r53-06m6's Avatar
r53-06m6
Thanks for being there. The bit didn't snap off in the hole. Good Dewalt variable drill is being used. Hard to get leverage down there actually. I might try a different bit if time allows...while I await the new oil pan.
DaRKsMCs
Mar 29, 2020 07:03 PM
matthew-w
21
Mar 29, 2019 03:42 PM
Flying Sq
Mar 16, 2015 12:19 AM
garretwp
Nov 7, 2005 10:58 AM
cdconsor
May 24, 2004 01:21 PM
