R50/53 Another ECM/ECU question
Old Aug 25, 2018 | 08:30 AM
OCR's Avatar
OCR
Car - 2005, S, JCW hatchback.
New engine and ECM/ECU. 2006, S.
Is the ECM/ECU dedicated to a particular car, or can multiple ECU/ECU's be interchanged in and out of one car ?
I just bought a second engine and will take it a little above the current engine (but still try to keep it California friendly !). It will most likely require different mapping than the current box has.
Can they just be swapped without any other work or any damage to something else ?
Mike
Old Aug 25, 2018 | 05:39 PM
A383Wing's Avatar
A383Wing
The ECU's are VIN specific......however, you can change engines from one car to another without problems.....the sensors on the engines don't care what car they are in
You have to use the ECU that came in the car....or you can send another ECU out to have it programmed to your vehicle
Bryan
Old Aug 25, 2018 | 06:38 PM
downshift1's Avatar
downshift1
The ECU has the vehicle's VIN in it but it can be re-written. It also is sync'd to the immobilizer system.
If you're just changing the engine you don't need to change the ECU. You can remap the ECU with the FA software from Bytetronik or others to fit your needs.
Old Aug 25, 2018 | 09:27 PM
OCR's Avatar
OCR
Great, thanks downshift1
So this Bytetronik company will remap as required ? Any others that are trustworthy ?
A383Wing, just saying "send it out" doesn't really help a guy that's, "looking" for help, and has no current idea on where to go for this work.
Mike
Old Aug 26, 2018 | 08:44 AM
downshift1's Avatar
downshift1
Yes, Bytetronik offers a remote mapping service, it works like this:
Install the FA software on your ecu (all that's needed is a basic laptop)
Purchase the Custom Remote Mapping (CRM) service.
You provide data logs via the software you installed
They send you an adjusted map to load on your ecu.
This gets repeated till your tune is complete.
02mini300
Aug 24, 2018 08:35 AM
bond_007
Feb 11, 2018 12:31 AM
mikew74
Jun 30, 2013 07:18 PM
pmfranke
Sep 9, 2009 03:29 PM
flyshooter
Jan 1, 2008 12:40 PM
