R50/53 Voltage dip with AC running at idle?
Old Jul 3, 2013 | 03:23 PM
joylove's Avatar
joylove
For those of you with a voltmeter gauge, how much does your measured voltage dip (at the point of measurement) when you have the AC on whilst stationary?
Mine drops from about 14V to about 12V when the electric fan toggles on and off. This is matched with a dip in the cabin fan speed.
Measurement is taken from from the radio harness in my car.
Car is idling at about 850RPM, there are no dips if the revs are over about 1000RPM.
Old Aug 25, 2018 | 05:10 PM
tommydoo66's Avatar
tommydoo66
So Lovejoy,
Did you ever get a response from anyone? It is normal for these cars to do that? Just started monitoring my voltage after an alternator replacement to keep on eye on it i am seeing the same thing.
Tom
Old Aug 25, 2018 | 05:32 PM
A383Wing's Avatar
A383Wing
My '04 R53 does the same thing......voltage comes right back up when starting out from a stop......
Bryan
Old Aug 26, 2018 | 04:18 AM
MVPeters's Avatar
MVPeters
Same here - 2002 Cooper S - 14.2V running, 12V+ up&down at idle with A/C fans on.
You're asking a lot from a relatively small engine & alternator.
Old Aug 26, 2018 | 03:51 PM
MINI33342's Avatar
MINI33342
You can have a shop that can access the ecu bump up the idle speed 50-100 rpm. Love it on mine, no low idle vibrations either.
mdutton11
14
Oct 26, 2015 01:47 PM
Marco Guardado
Sep 15, 2015 01:22 AM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
Lt. Dan
Aug 10, 2015 12:46 PM
Lt. Dan
Aug 10, 2015 08:23 AM
