R50/53 2003 Mini Cooper Motor Blower Removal
Old Jul 23, 2018 | 08:19 AM
alexdtech's Avatar
alexdtech
Hello,
Does anyone know how to remove the Motor Blower for 03 Cooper?
Old Jul 23, 2018 | 11:06 AM
twokbolt's Avatar
twokbolt
You'll want to put the car in front end service mode. There's a youtube video by minimods that is very helpful here:
Old Jul 23, 2018 | 01:57 PM
JAB 67's Avatar
JAB 67
I think the question relates to the cabin-air-handler, not the engine fan or supercharger.
Old Jul 23, 2018 | 02:25 PM
If its the heater fan then here:
https://www.newtis.info/tisv2/a/en/r...ntrols/Oiu3vnm
Some info here but its simple:
https://www.newtis.info/tisv2/a/en/r...ater-controls/
Old Jul 23, 2018 | 03:24 PM
JDM_'s Avatar
JDM_
Good info. Mine sounds like baby birds are in my dash. Lol.
Old Jul 23, 2018 | 06:07 PM
twokbolt's Avatar
twokbolt
Oh haha. Totally missed that.
Old Jul 24, 2018 | 11:12 AM
Welcome. Yes i have heard the chirp in other MINI fans.
Old Oct 4, 2021 | 12:18 PM
AndrewCandy's Avatar
AndrewCandy
Helpful insight some years later
Originally Posted by alexdtech
Hello,
I recently fought through a blower motor replacement on my 06 r50 and I want to make this job easier for anyone who tries after me. YOU DO NOT NEED TO REMOVE THE DASH. Please let me save you some time!
Caveat: I have a US car with left side drive. I imagine the process is similar for models with the driver on the right, but I don't know for certain.
Step 1:
Remove the two trim pieces below the steering column and disconnect the intermediate steering shaft at the upper U joint
Step 2:
Remove the cabin air filter. You should be able to stick your arm into the air filter box and feel the fan blades.
Step 3:
you should have enough clearance to remove the blower motor housing from the driver side. There are 3 torx screws (I believe t25) holding in the plastic housing, and some of them are hard to get to due to the large wiring harness that runs around the housing. Look up a picture of the part online to help orient yourself.
Step 4:
You can pull out the old motor with a bit of force or you can remove two more torx screws from the end of the housing that hold the motor in the housing. This will allow you to separate the part into two pieces that can easily fit through the space we made earlier. It helps to have a second person holding the motor from the passenger side as you remove the housing otherwise it is difficult to separate the parts.
Step 5:
Once you have the old motor out, take the new motor and remove the two screws that hold the motor into the housing. Put the motor into position from the driver side without the housing and have your helper hold it tight against the filter box from the passenger side. They should be holding onto the fan basket.
Step 6:
While the motor is being held in position, put the motor housing onto the back of the motor and screw it in with the three outer torx screws. Do not yet insert the two screws that hold the motor in.
Step 7:
Have your helper who is holding the motor by the basket spin the motor in the housing. This is somewhat difficult, and feels very different from just spinning the fan blades. While the motor is spinning, use a mirror or a smartphone to get a good view of the back of the motor housing and look to see when the motors threaded holes line up with the two screw holes in the housing.
Step 8:
Once you see that those two holes are lined up, reinsert the two remaining torx screws, plug it in and test it, then reattach the U joint, filter, and trim pieces we took off in steps 1 and 2.
This is widely considered one of the worst parts to replace on the gen 1 minis, so hopefully this will save you the pain of removing the whole dash.
Old Jan 23, 2022 | 03:13 PM
65C10's Avatar
65C10
I need to do this job but the links above no longer work; are you still able to assist me by pointing me in the right direction so I can do this myself?
CVheers
David
Old Jan 23, 2022 | 06:09 PM
deepgrey's Avatar
deepgrey
The BMWTIS website or the Bentley should have the procedure.
Old Jan 24, 2022 | 11:29 AM
Yep they killed the site. You have to pay for the BMW TIS site or dig through here: https://workshop-manuals.com/mini/
Or get the Bentley
https://www.ecstuning.com/b-bentley-parts/v-mini/
Old Jun 17, 2022 | 08:51 AM
ST3ALTHPSYCH0's Avatar
ST3ALTHPSYCH0
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
I have been using cobbled together hacks for YEARS avoiding the headache of removing the dash.... You have given me hope of proper conditioning again.
Does anyone know if the squirrel cages are swappable on these assemblies? My 3 pole motor is actually fine, my cage broke, so it's nastily off balance.
Old May 20, 2024 | 08:23 PM
YakiMini's Avatar
YakiMini
I just did it April 2024 and didn't drop the steering shaft. It can be done even easier.
Old May 21, 2024 | 07:25 AM
cooper48's Avatar
cooper48
https://www.realoem.com/bmw/enUS/par...-Mini-Cooper_S
Old Jul 23, 2024 | 06:01 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I did it the fun way. Had to replace the blower motor a the ac temp actuator. Was a pain to find a replacement.
Old Nov 26, 2024 | 12:59 AM
yellowR50's Avatar
yellowR50
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Hi I'm just about to do this please could you tell me how I to disconnect the intermediate steering shaft Thank you
Old May 13, 2025 | 09:15 PM
noodlesandsam's Avatar
noodlesandsam
question - there is a 2 pole fan motor and a 3 pole fan motor - is the 2 pole for manual HVAC, and the 3 pole for Automatic HVAC? I see a reference to 67326901862 - and it says for automatic hvac. Does anyone really know, before I order?
Old May 14, 2025 | 03:13 AM
Scoobaru2010's Avatar
Scoobaru2010
Yes you are correct, 2 prong for manual, 3 for auto. You can pop the plug off your blower without almost no disassembly by just removing the plastic cover in the footwell to confirm your suspicions!
Also if you have not done this job yet its like a Mini yoga class.... You may be cursing the car by the end
Best of luck
Old May 14, 2025 | 04:54 PM
noodlesandsam
Ah fun times. I did a heater motor in a 79 Volvo 260, so I understand this kind of masochism. Of course, that was decades ago…..
Angel Banda
Jan 31, 2022 08:15 PM
rdennisj
Feb 22, 2020 02:28 AM
Dave Elliott
May 8, 2016 06:04 PM
q-uest
Dec 19, 2014 03:39 AM
