R50/53 Big Dumb Guy Question - R53 Floor mat slldiing around
Old Jun 4, 2018 | 09:24 AM
Bear's Avatar
Bear
Feel like a dum_ss, but I am tired of this little issue
I have a '05 MCS R53 with OEM rubber floor mats. The driver mat just keeps sliding forward and crams up against the pedals. Is there a way to secure the mat so it does not slide? I'm guessing they came with something...but its not there... Thanks, it's annoying the heck out of me
Old Jun 4, 2018 | 09:34 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
My experience does not agree with yours. The driver side rubber floor mat has Velcro pads that are intended to prevent it from sliding forward. They are not well align the counterparts on the floor carpet. Despite of this my OE rubber mats are the best of any rubber mats I have ever own. They stay put very well due to the generous weight, traction features on the underside, and most importantly perfectly designed to fit around all the features of the floorpan, accelerator and deadman pedals.
I don't even take them out driving on tracks as they are so secure.
Old Jun 4, 2018 | 09:42 AM
Bear's Avatar
Bear
Mine do not have the velcro underneath...that's why they slide. I wonder if I could get replacement velcro? Do you know of any place? Or idea?
Old Jun 4, 2018 | 09:46 AM
pnwR53S's Avatar
pnwR53S
Each time I remove the rubber mats to vacuum I have never felt the Velco pads are doing anything, but I can be wrong. Are you sure you have the genuine MINI rubber pads? May be there are more than one. Please post photos.
Old Jun 5, 2018 | 05:45 AM
MiniTigger's Avatar
MiniTigger
Mine slides around too - so I guess I'm missing the pads as well. I routinely get in the car and pull the mat back to the seat rails. I'm switching to Weathertech's anyways, so it doesn't really matter at this point.
Old Jun 5, 2018 | 07:10 AM
vetsvette's Avatar
vetsvette
Moderator
Do you still have the OEM carpeted mats installed? I have my rubber ones on top of the stock mats and have the slipping problem. I'm always saying that I'll pull the carpeted ones and try the all weather alone, but never think of it until times like now.
Old Jun 5, 2018 | 07:28 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
You can buy industrial strength Velco tape at big box stores or Amazon online. Pretty simple fix, just make sure all surfaces are cleaned prior to install.
Old Jun 5, 2018 | 07:10 PM
MiniTigger's Avatar
MiniTigger
Easier (and cleaner) to install weathertech's.
Old Jun 5, 2018 | 07:58 PM
vetsvette's Avatar
vetsvette
Moderator
No doubt, but I like the looks of the JCW Pro all weather mats better.
Old Jun 6, 2018 | 05:31 AM
MSFITOY's Avatar
MSFITOY
Agree with Weathertech...better function and fits excellent...
http://northamericanparts.com/i-1815...kaAnd5EALw_wcB
Old Jun 6, 2018 | 05:43 AM
Subw00er's Avatar
Subw00er
Had same problem, bought the mini rubber matts, no more issues!
Old Jun 6, 2018 | 07:17 AM
pnwR53S's Avatar
pnwR53S
We must have different MINI rubber mats from those report sliding. I fail to see how mine can slide around even if the velcro are not there. The features of the accelerator and the dead pedal prevent it from moving forward. The floor pan has very steep side walls and the stiff mat just does not try to climb in all 4 directions.
Putting these mat on top of another set of mat is to invite trouble as one above reported how he use them.
Old Jun 6, 2018 | 12:20 PM
Bear's Avatar
Bear
Got a fix...
All the banter aside...These are real OEM Mini S rubber mats...and the driver side mat kept sliding forward.
Velcro would not grab the carpet so that is out.
I got a fix. I used two small/short bungy chords which I attached to the back edge of the mat. I looped the bungy chords around a good anchor under the front side of the driver seat. Can't see it unless you look under the seat and it keeps the mat from sliding forward...done.
Thanks for all the conversation
Old Jun 6, 2018 | 01:40 PM
MiniTigger's Avatar
MiniTigger
I'll try to get a pic of mine later - but they move too.
Old Jun 6, 2018 | 01:41 PM
MiniTigger's Avatar
MiniTigger
Nice solution. Like I said, I'm switching mine out - so my issue will be resolved too.
Old Jun 6, 2018 | 01:51 PM
HaltCatchFire's Avatar
HaltCatchFire
My OEM mats move all over the place and there's no velcro - I'll try the bungee and see if that helps!
Old Jun 6, 2018 | 01:58 PM
MSFITOY's Avatar
MSFITOY
I finally swapped my OEM rubber mats to Weathertech because of the weight difference...also WT is dished and much more effective at protecting the carpet...
Old Jun 6, 2018 | 02:04 PM
pnwR53S's Avatar
pnwR53S
My rubber mat might just move if someone strangle me from the back seat with a steel wire. I can't see it move even driving on the track with happy and restkess feet.
Old Jun 6, 2018 | 08:20 PM
Subw00er's Avatar
Subw00er
I originally had the carpets, and switched to rubber .They are solid, I agree.
Old Jun 6, 2018 | 08:35 PM
pnwR53S's Avatar
pnwR53S
Leave me wonder if those experience sliding have rubber mats that has deteriorated from hot sun exposure. My velcro is doing nothing as the guy at Classic Mini did a crap job placing the floor side not aligned with that on the carpet at all.
Perseus
Nov 8, 2012 09:51 AM
fishey72
May 22, 2012 11:52 AM
