R50/53 Magical Mystifying Key
Old Apr 28, 2018 | 12:22 PM
MiniTigger's Avatar
MiniTigger
The scenario:
R53 06S - There are 2 keys - Key 1 works fine all the time. Key 2 will unlock the car but will not lock the car. It changes for a second if you put Key 2 in the ignition (in acc mode) and leave it there for a little while (say 30 mins), it will lock the car and then unlock it - but will not lock it again.
Any ideas?
Old Apr 29, 2018 | 05:27 PM
MiniTigger's Avatar
MiniTigger
Beuhler .....
Old Apr 29, 2018 | 07:45 PM
ItsmeWayne's Avatar
ItsmeWayne
You most likely need to reprogram the keys!
Old Apr 29, 2018 | 07:57 PM
rkw's Avatar
rkw
Possibly the battery in the key is dying and only able to hold a very weak charge (enough for a lock/unlock cycle but not more). Does it work if you hold the key close to the rear view mirror (where the receiver is)?
Unfortunately the 2006 key is not designed for replaceable battery, but it can done if you cut open the key and unsolder the battery. https://www.northamericanmotoring.co...ob-repair.html
Old Apr 29, 2018 | 08:00 PM
MiniTigger's Avatar
MiniTigger
Even though they start the car, and do unlock it - but one (Key 2) locks it intermittently? Again, no problems with Key 1. Key 2 never fails to unlock it and after it's been running for awhile, it will lock it but it will not lock it more than once - always unlocks it though.
Old Apr 30, 2018 | 02:27 AM
rkw's Avatar
rkw
Starting the car involves the immobilizer chip in the key, which is completely independent of the remote lock/unlock electronics. The immobilizer chip doesn't require power and doesn't use the battery in the keyfob.
If key 2's behavior is changed by running the car with it for awhile, then I thought it could be a battery issue. The car recharges the key's battery while the key is inserted and the car is turned on. The battery might not be holding a charge but charging could give it enough power to work temporarily.
You described the following sequence:
1. car running with key 2 for awhile
2. lock car with key 2 – successful
3. unlock car with key 2 – successful
4. lock car with key 2 – unsucessful
Just to clarify... by your description you could then lock using key 1 and unlock using key 2 repeatedly without issues?
You could try reprogramming the keys as already suggested (https://www.northamericanmotoring.co...ml#post1462932). Another possibility is that the physical switch for the lock button is only making electrical contact intermittently.
Old Apr 30, 2018 | 05:03 AM
MiniTigger's Avatar
MiniTigger
I agree with your line of thinking that it could be the battery - but wouldn't that also affect unlocking?
This is correct.
Old May 4, 2018 | 03:11 PM
RLucky82's Avatar
RLucky82
This is correct.
I only have one key but mine does the same thing. I believe it is a weak battery, Here is why. It will unlock from 20 or 30 ft. But usually has trouble locking no matter how close. Now, if I touch the key to a metal part of the car, say door lock or even passenger door handle it works fine every time. Give that a try...
Old May 4, 2018 | 04:53 PM
valvashon's Avatar
valvashon
I do key repair on the side as "MINI Key Hospital". It is odd that it only locks the car once but it is most likely a failed/failing battery. Here's how to see if it's any third button push. Put key 2 in the ignition as before (I think you said 30 minutes). Pull key 2 out. Instead of using it to lock the car, use key 1. Then use key to to 1) unlock 2) lock 3) unlock again. I'm guessing that the third button push, no matter what it is (you could try this again with the hatch unlock as the third push) will fail. This indicates very rapid voltage drop in the battery.
A very common problem with these keys is that the battery breaks away from the board due to vibration. One of the battery legs is half as thin as the other which makes it easy to break. Often when this happens key functions are intermittent and sometimes the key ceases to work at all. Perhaps pushing different buttons on the board changes the angle of the board enough to make or break contact with the battery leg.
It's difficult to explain why the key always unlocks the car, though. If it's not battery drop then there certainly is a loose switch connection- either the switch itself is bad or there is a bad solder joint.
If you'd like me to take a look at your key and diagnose the intermittent issue please send me an e-mail to "minikeyhospital@outlook.com" (sorry about my PM box being full at the moment).
One word of caution, opening these keys is tricky. Cut too deep and you end up slicing components off of the circuit board, and then that's it for the key.
Dr. Bruce Hart
MINI Key Hospital
Old May 5, 2018 | 06:30 AM
RLucky82's Avatar
RLucky82
Dr. Bruce Hart
MINI Key Hospital
That sounds more like the problem I am having, because my unlock is intermittent also. forgot to add that in the first post.
Old May 7, 2018 | 07:52 AM
MiniTigger's Avatar
MiniTigger
Dr. Bruce Hart
MINI Key Hospital
I am able to unlock it what seems an unlimited amount of times. Locking is the questionable thing. It does it sometimes and not others. Unlocking always works.
Old May 8, 2018 | 11:33 AM
JAB 67's Avatar
JAB 67
Valvashon put a new battery in my 2004 key years ago; I recommend him.
zied
36
Oct 7, 2008 09:15 AM
trplezero
MINI Collectibles
22
May 1, 2007 10:00 PM
MSFITOY
May 15, 2006 07:54 AM
