R50/53 Help!! Emergency!!
Old Oct 24, 2004 | 04:48 PM
  #26
lotsie's Avatar
lotsie
Originally Posted by brian@EuroStylesEast
Mine did this today...not even 400 miles on it Tried the normal tricks lock/unlock, battery disconnect, etc. Finally got it going by pushing it and dumping the clutch.
Worse off, it happened at a car show...I couldn't get my mini in any of the group photo shoots I had to wait 'till everyone left to push start it, so it didn't look like ESE's new project car was garbage.
Dealer says it's the ecu/security, but if that's the case why would it push start?
I'm not going to have any one here at the shop even waste their time on it. The dealer is getting dumped with this problem, since it's so new
Interesting how you could push start it.Must try this push starting thing.Judging by how well it cranks over and goes,it may be a second gear drop of the clutch to get it going.Nice to know.I,ve pushed started every other standard tranny car I've owned,why not this one
You had the key in the ignition,that's why it started.Maybe
Old Oct 24, 2004 | 05:42 PM
  #27
goldcountrymini's Avatar
goldcountrymini
FYI with the battery... make sure if you dont buy a battery from the dealer that you get a batter that is vented. If you dont vent it or get one that is vented.... it could be fatal. REALLY. Those fumes come from the battery inside the car and it can be a bit nasty. I figured that I better post that incase anyone buys to the autopart store for aftermarket battery. The MINI/BMW battery should last a long time being in the boot. The highest causes of battery faliure are HEAT and VIBRATION... being in the rear of the car and strapped down really well decrease the amount of "wear" on the cells inside the battery.... just and FYI
Old Oct 24, 2004 | 06:06 PM
  #28
lotsie's Avatar
lotsie
Letting it freeze does no good either
Old Oct 25, 2004 | 08:34 AM
  #29
early_apex
The chip in your key could be bad. Do you have another key or a credit card spare you could try?
Old Oct 25, 2004 | 09:14 AM
  #30
holdenontoit's Avatar
holdenontoit
I talked with one owner who had GPS ,who had problems with the gps killing the battery by costantly rebooting itself,even with the car parked!FWIW
Old Oct 31, 2004 | 05:47 PM
  #31
OctaneGuy's Avatar
OctaneGuy
Dead Battery
I went on a trip to Orlando for a week, came back, and eager to get my MINI fix, I put my key in the ignition, and it barely turned over.
I took the car out for a spin and everything seemed fine, but about a mile from my house, the flat tire warning indicator came on. I went home and checked my tires, and my left rear tire was 20 pounds!! OMG.
This tire had a minor puncture that I had looked at a couple months ago, but was deemed not a deep enough puncture to need repair.
3 days later, I haven't driven my car, I go to retrieve an item from my boot, and it won't unlock. I look at my driver/passenger doors and the doors are unlocked. I hit the remote unlock several times and nothing happens.
I put the key in the ignition, and turn it---with the clutch in. Nada. No lights, no sounds. I try a few more times, and the passenger seat belt warning light dimly lights up, then goes out.
Fortunately I have a battery charger so I put it on my battery. A few minutes later, when I put the key in, the interior lights and dash come on, but the car makes a clicking sound. So I leave the charger on for a few more minutes, and now the car starts.
My car is 13 months old. I didn't have the battery on, nor do I have any devices that would drain the battery--no amps, no aftermarket headunit, etc.
The only thing that happened while I was in Orlando was that it got really cold--and rainy--even though my car was garaged. Strange.
My car is drivable now and I have an appointment with the dealer tomorrow, so I guess I will have it looked at. But it's strange.
Old Oct 31, 2004 | 06:18 PM
  #32
lotsie's Avatar
lotsie
Even though not lit up the clock is running.Do the computers shut right down,I don't know
Old Oct 31, 2004 | 08:08 PM
  #33
CruzinChris's Avatar
CruzinChris
Originally Posted by dgszweda1
I think you have the dreaded "Bing Bing" Virus. It has happened to a few people with v38 or higher software. Have you been sharing any fluids with other Minis?
I think it is great that everyone just ignored your "input"! When folks come to this board with a real-time problem the last thing they want is a smart a88.
Old Nov 1, 2004 | 05:40 PM
  #34
lotsie's Avatar
lotsie
Up here in the great white north,you learn to turn off everything when you park the car,heater fan,radio.Open the door get in fast so interior light is on for a short a time as possible.
Newer cars,MINIs included,have lots of things running when they sit parked,and lights and things turn on when you unlock and get in.The heated mirrors are on,plus the washer heaters are on at click 2 of the key.Lots of drain on the battery before you crank the motor.
My MC started all last winter,no block heater,never used the charger I bought,unless the car was going to sit for more than a day.
If the car is going to sit for any kind of time,use a SMART battery charger.Mine goes into the lighter,and only charges if the battery amps drop to a certain level.Low level charging is not hard on the battery.
Old Nov 2, 2004 | 04:48 PM
  #35
Brian Spielman's Avatar
Brian Spielman
Well, looks like my problem was an isolated issue...a pin was found to be bad from the clutch switch module to the ews. Makes sense why I was able to push start it and why it wasn't an ecu/security issue like they first predicted
Old Nov 3, 2004 | 10:03 AM
  #36
RaiderZA's Avatar
RaiderZA
Battery booster pack
Originally Posted by The_Beastmaster
One thing I learned about BMWs is to never jumps start your car! With all of the sensitive electronics in your car, jumping it with another car can damage something. My car was jump started by AAA one time (they came with a souped up car from a service station) and it fried my SI board. My advice is for you to purchase a booster pack. I have 2 of these and they work great!
What kind of booster pack do you use? The one I have is quite large and warns against exceeding 100 deg heat, which can be a problem in my boot in the summer!
Etrain
16
Aug 5, 2024 04:37 AM
Apr 7, 2020 06:49 PM
Toolman
Jan 20, 2016 06:50 AM
ti22fjc
Aug 9, 2015 05:49 PM
Calvin77
55
Jan 4, 2003 04:22 PM
