R50/53 Flat monitor 2005 MCS
Old Sep 7, 2004 | 08:06 PM
winechic's Avatar
winechic
I recived my '05 MCS on Sunday and yesterday the flat indicator went on. Car was turned off restarted and no light. Little way down the road it comes back on. checked the tire pressure, all seemed fine.
Does anyone know if this is still a glitch in the '05 models? Also, has anyone had it fixed, succesfully or not?
any thoughts welcome.
and thank you.
Old Sep 8, 2004 | 09:33 PM
lotsie's Avatar
lotsie
While the car is running hold the button down that is under the E-brake till the low tire light stays solid,release the button and push again,should go out.
But if the car is brand new,get the dealer to make sure the beads are good on the tires.I had a real slow leak from the factory that did not show up till it was -40,scary on the highway
Old Sep 9, 2004 | 07:36 AM
winechic's Avatar
winechic
Thank you. I got off work at an almost normal hour last night so I was able to read the manual, and check the pressures. It seems that maybe the sencor was not initallized, according the the owners manual. We shall see.
Thanks again for your help.
iggi
18
Feb 9, 2026 01:00 AM
khumpert
Nov 30, 2015 11:48 AM
mdutton11
14
Oct 26, 2015 01:47 PM
ericbryant24
Aug 29, 2015 01:55 PM
Tristankix
Aug 24, 2015 04:39 PM
