R50/53 Confused by 5E19, 5DC3, 5DB3 codes
Old Jan 25, 2016 | 03:51 PM
RocketUSA's Avatar
RocketUSA
I've been fighting with my airbag light lately (another story, I think) and thought I would read some other codes as well. I had no warning lights on the dash, I was just playing around in the software. I turned up the following:
Code:
5E19 CAN data fault from DME/DDE(DCS lamp on as long as error is preset)
5DC3 Wheel-speed sensor, rear right
5DB3 Wheel-speed sensor, rear left
5E5C Initialize Run Flat Indicator, see Owner's Handbook
These codes won't clear, but they don't manifest as warning lights. What gives? Is this normal to find sneaky codes like this?
Old Jan 26, 2016 | 11:31 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Looks like you're reading faults in the ABS/DSC system. Most of what I am finding on them is with a DSC/SES light on. Is your DSC and ABS working as it should? Some info HERE. This member HERE has similar issues to what you're having and seems to be active. Maybe PM him and see what he did to resolve the issue. I'm thinking they might be old codes if you aren't seeing any issues. Could be the tool cannot reset them maybe?
888.280.7799 | 6am - 5pm PST
Old Jan 26, 2016 | 11:37 AM
RocketUSA's Avatar
RocketUSA
The system appears to be active. The light comes on when I think it should, and it feels like it is too. The tool did fine resetting the airbag, so I feel ok about it's capabilities. I'll check out those links, thanks!
Old Jan 26, 2016 | 02:32 PM
PelicanParts.com
Vendor
Sometimes when a smog is done the system sets fault codes, but no light. Usually they are speed sensor faults. You could try disconnecting the battery then touching the two leads together to discharge the capacitors in the modules. Then, leave it disconnected for another 30 minutes and see what happens.
Gloriakogg
Jul 27, 2023 07:11 AM
sir5150
Jan 23, 2016 10:45 AM
Piano Man
12
Jan 22, 2016 07:15 AM
amajormini
Jan 21, 2016 10:23 AM
MiniZimmy
Jan 19, 2016 07:09 PM
