Mystery Vacuum line
Old 01-22-2016, 04:50 AM
supermini23's Avatar
supermini23
supermini23 is offline
Mystery Vacuum line
i recently had the engine out of my car and after the install I realized I forgot to connect this vacuum line. I remember disconnecting it. I can not for the life of me figure out where the hose is i connect it too. I have it plugged for now and still runs fine. No CEL.
2004 Mini Cooper non-supercharged
Old 01-22-2016, 07:05 AM
AoxoMoxoA's Avatar
AoxoMoxoA
AoxoMoxoA is offline
It connects a rigid plastic vacuum line (which sits directly underneath the two lines you have it propped up on) to the intake manifold.
Here's mine...
Old 01-22-2016, 07:21 AM
supermini23
Where does that hose go? That rigid hose is not there on mine and I don't think my connecting hose was rigid. If I remember right it was another rubber connector like the one with the screw in it in my picture and it had a straight butt type connector between the two of them. After the rubber connector, was a small diameter plastic hose. If i knew where it was routed too I could trace it backwards. Gas tank?
Old 01-22-2016, 07:30 AM
AoxoMoxoA's Avatar
AoxoMoxoA
The vacuum pipe, as it is called (the part you reference), connects to the fuel rail at the intake manifold, then to another rigid vacuum line which snaps into the holder directly underneath the top (rigid) one in your picture, then runs parallel (to the top rigid line) down the firewall and back to the fuel tank.
Old 01-22-2016, 07:37 AM
supermini23
Great thanks. I'll trace it back from the fuel tank then.
Old 01-22-2016, 08:20 AM
Unbreakable Lump's Avatar
Unbreakable Lump
Unbreakable Lump is offline
It's the purge line from the charcoal vapor canister. The canister connects to the fuel tank to absorb hydrocarbon vapors. That line feed into the intake manifold to burn those vapors. The release of those vapors from the canister is controlled by a solenoid valve, called a purge solenoid. It's an important part of the emissions system.
Old 01-22-2016, 08:32 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Here's another pic, with arrows pointing to the rigid line it connects to...
Note that I've lifted the breather hose from its holder to illustrate where the line is, and where it goes.
Old 01-22-2016, 09:16 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
Looks to be the Fuel Pressure Regulator Vacuum Line, which I believe connects the fuel pressure regulator to the intake manifold and the tank vent, #11 below - part number HERE.
Edit: So on this diagram, I think it connects into the fitting of the vacuum pipe (#4 - part number here) going back to the gas tank area or vapor canister. (As stated above).
888.280.7799 | 6am - 5pm PST
Old 01-22-2016, 10:02 AM
supermini23
Pelican Parts, I think you got it right. Part 3 in your second diagram is the purge solenoid hose which you can see in my initial picture. Why there is a constant flow vacuum hose (part 4) going back towards the fuel tank is beyond me......Do you know what it connects to back there?
I must have tucked it behind the heat shield or something when pulling the engine. I'll just have to dig for it!
Old 01-22-2016, 02:52 PM
yesti's Avatar
yesti
yesti is offline
Listen to unbreakable, he designed the engine.
Old 01-22-2016, 03:38 PM
Unbreakable Lump
I've been wrong before. Wouldn't be the first time. Hard to tell sometimes from a picture. Most engine intake manifolds will usually have 2 or 3 nipples: for PCV, evap purge and sometimes a separate one just as a vacuum input to other stuff (like fuel pressure reg.). I think the Mini tees off the purge line for that per Pelican's part diagram
Old 01-22-2016, 03:49 PM
yesti's Avatar
yesti
yesti is offline
Even going off a picture your educated guess is a great place to start, if not dead on. Even though I have a R56, I've enjoyed reading your various posts, forum stalking haha.
Old 01-23-2016, 05:31 PM
supermini23
Thanks for all the help guys . I found the end of the hard line going into the wire loom below it. So was planning tricks with me. All good now. Some great guys on here with lots of good info.
Old 11-21-2017, 08:03 PM
eddie33brian's Avatar
eddie33brian
eddie33brian is offline
Here's mine...
I have this line (the one you circled here) broken at the end under the intercooler tube. Do you know the part number or any reference?
thank you !
Old 11-22-2017, 05:08 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
It appears that Pelican Parts has noted that part in their post #8 with a link to the part number.
PelicanParts.com (11-22-2017)
Old 11-25-2017, 10:57 AM
sarom058's Avatar
sarom058
sarom058 is offline
Location: Portland, OR *currently in a temporary email address
IIRC, there's a hard plastic line that clips to the underside of that bracket, with a spot for that connector to attach to. I might have a spare lying around somewhere, I can check today.
Edit: Whoops, another case of me not reading the thread. Sorry guys. Feel free to delete this, coop
Old 11-27-2017, 07:01 PM
eddie33brian
See below
Old 11-27-2017, 07:04 PM
eddie33brian
I have that same rigid line with the cone fitting at the end of it. It is sitting on my intake, underneath the intercooler, on my R 53. It’s not connected to anything and I’m wondering where it goes.
I recently found that fuel pressure regulator vacuum hose broken at the 3 way connector under the inter cooler and I already reconnected that one. I’m still having issues throwing the P0340 code and having no power, and missing at lower RPMs with moderate to heavy throttle.
Old 11-28-2017, 06:55 PM
sarom058's Avatar
sarom058
sarom058 is offline
Check realoem.com for the best parts diagrams for these cars. I'm not too sure which rigid line you're talking about, there's quite a few.
Once you find out, let me know and post a picture. I might have one lying around I can get to you for whatever you can afford+$10 shipping to the continental US. Might be cheaper than buying it new.
Old 11-28-2017, 07:14 PM
eddie33brian
The vacuum line I found went from the fuel rail to the tube for the inner cooler. No big deal I hooked it back up and the problem remains the same. I’m still throwing that same P0340 camshaft position sensor fault code and then the car starts running funny and has no power at the low-end. So I’m back where I started trying to figure out why I am throwing those codes, and it’s not the camshaft position sensor so it could be any number of things that would also throw that code. i had read 5 other things that can throw that code including the crankshaft sensor which I do not want to fix since you have to take the whole front end of the car off. (front end service mode)
Anybody know a good Mini mechanic in Southern California that won’t charge me for the diagnosis?
Old 11-28-2017, 07:25 PM
sarom058's Avatar
sarom058
sarom058 is offline
Most shops will give a free diagnosis if you ask nicely and have the part replaced there. I doubt any shop will diagnose for free and let you drive away without paying for their diagnosis time, though. MINI dealers charge $100 for a full diagnosis and inspection.
Alternatively, if you just want the part replaced, check yelp for your area. Search "european auto service" and go to a shop with 5 stars and 50+ reviews.
By the way, if you have the time to learn, front end service mode is a piece of cake after the first time. Won't take more than 15 minutes once you get it down. ModMINI has a great video on YouTube.
Dig deep, there is a wealth of knowledge on here. Once you're working on it, be methodical and work from one end of the system to the other. Don't be afraid to go to your friendly local dealership and ask the service department leads/common fixes. If you have the time/interest, you'll figure it out.
Old 10-09-2018, 07:01 PM
RabbiTim's Avatar
RabbiTim
RabbiTim is offline
Can you tell me where the driver side of the hose goes?
Emnotek
01-13-2016 11:49 AM
12-06-2015 08:44 AM
12-03-2015 11:18 AM
Quick Reply: Mystery Vacuum line
