R50/53 r53 no crank
Old Aug 2, 2015 | 10:22 AM
  #26
The_Kid's Avatar
The_Kid
yea. i know the car had just been to the mini shop right before failure due to a low oil light. they found sludge in the filter housing. honestly i went into it with the thought that it may need an engine and even then im going to be around 2500 into the car. so it wont hurt at all.
im going to pull the serpentine belt and try to rotate again to make sure something else isnt locked up. and if that fails gonna pull the head off by the end of today and get a visual
Old Aug 2, 2015 | 10:56 AM
  #27
ZippyNH's Avatar
ZippyNH
Car does not have a low oil light....
Just a low oil psi light...
It was on...
The MOTOR is done. Junk it. It's toast.
Nuff said.
Save your $$, change the motor .
Old Aug 2, 2015 | 11:15 AM
  #28
The_Kid's Avatar
The_Kid
Ok the work was done at 159428. The car currently has 162270. Here is a pic of the write up.
Old Aug 2, 2015 | 11:18 AM
  #29
ZippyNH's Avatar
ZippyNH
Originally Posted by The_Kid
yea. i know the car had just been to the mini shop right before failure due to a low oil light. they found sludge in the filter housing. honestly i went into it with the thought that it may need an engine......
As an old time radio announced used to say "and now we know the rest of the story.".
Even if you unlock it...every part is now suspect...the cam is usually pretty well messed up, and MINI engine parts are so $$, best option is swap it..
Just be sure the motor came out if a good running wreck...
Many a MINI have run low on oil...
Old Aug 2, 2015 | 11:23 AM
  #30
ZippyNH's Avatar
ZippyNH
Now 100% sure junk the motor...
The car requires syenthic oil..and sludge usually is from dino oil...
Since the owners address, name, and phone is on that sheet...you might want to take it down, or cross it out and repost it...
Old Aug 2, 2015 | 11:30 AM
  #31
The_Kid's Avatar
The_Kid
Gotcha didn't think about that.. deleted the other pic. But I'll put this one up just for referance.
Old Aug 2, 2015 | 11:32 AM
  #32
The_Kid's Avatar
The_Kid
well. ill have to clean a spot in the garage and get it rolled in and start taking the front end off. i work out of town during the week so only leaves weekends. so ill get everything ready for a new donor replacement. is there any tips/tricks to the job as this will be my first mini engine swap.
Old Aug 2, 2015 | 04:15 PM
  #33
The_Kid's Avatar
The_Kid
i think im going to start another thread. now that the problem is apparent. and have it be a ressurection thread
Old Aug 2, 2015 | 05:20 PM
  #34
The_Kid's Avatar
The_Kid
Posted this on the other thread but here it is.. Motor is not locked spins freely however the super charger is toast. So replace the charger or just swap it all
Old Aug 2, 2015 | 05:21 PM
  #35
The_Kid's Avatar
The_Kid
heres the link head on over
https://www.northamericanmotoring.co...k-the-r53.html
09R56
Nov 16, 2022 10:49 AM
Inziladun
Sep 3, 2015 10:35 AM
mackedmini
Aug 20, 2015 02:35 AM
vanhick
Aug 19, 2015 09:03 AM
keck.j
Aug 18, 2015 08:18 PM
