R50/53 Supercharger oil change question
Old Jun 30, 2014 | 10:40 AM
MINI Gunner's Avatar
MINI Gunner
Is it possible to top off the SC oil without removing it and tearing the entire front end apart?
If your answer is no, please just vote in the poll.
If your answer yes, please tell me how you did it.
I did a search on here and there seams to be a consensus but I want to verify since I like to be optimistic about things being simple.
Old Jun 30, 2014 | 10:43 AM
MINI Gunner
For some reason I can't do a poll, there is not poll check box or button like there is suppose to be, just do a quick reply with your answer.
Webmaster/admins, can you please help me with the poll issue I am having. Wyam I not seeing "post with a poll" as an option?
Old Jun 30, 2014 | 11:12 AM
ZippyNH's Avatar
ZippyNH
No need to pull a poll...
Answer is NO.
IT MUST BE REMOVED AND TIPPED to fill...have a spare SC ON THE SHELF....
remember...there are two filling bungs...one is the snout...all sc have this....the other is the issue on the mini...the water pump PTO...the bung is under the water pump mounting area...and in the wrong spot to fill if not tipped.....
Old Jun 30, 2014 | 03:16 PM
2Miniacs's Avatar
2Miniacs
^+1
Old Jun 30, 2014 | 05:16 PM
bavmotors's Avatar
bavmotors
I wondered this also, what a bummer. They really should have made it easier somehow.
Old Jul 1, 2014 | 06:46 AM
MINI Gunner
If I flipped the car over could it be done?
Old Jul 1, 2014 | 07:13 AM
JAB 67's Avatar
JAB 67
Somebody does make a device that permits you to change the s/c oil without disassembling anything but in order to install it you have to disassemble everything.
Old Jul 2, 2014 | 05:56 AM
speed6's Avatar
speed6
Is there a good DIY / how to on this anywhere. I have searched the site and come up empty.
Chad in Tulsa
Old Jul 2, 2014 | 06:07 AM
buzzsaw's Avatar
buzzsaw
Old Jul 2, 2014 | 06:08 AM
ZippyNH's Avatar
ZippyNH
Chad in Tulsa
There are several....last time I searched I found 2 good ones in 5 minutes...pages of pictures...
Any S gen1 water pump replacement or sc swap threads....
Old Jul 2, 2014 | 06:20 AM
05Whitey_Bulger's Avatar
05Whitey_Bulger
Ive been looking for that setup as well, discontinued? deleted?
Old Jul 2, 2014 | 07:46 AM
AllPepperS's Avatar
AllPepperS
http://www.imperialmini.com email Sean, he can fill you in, but in order to install they do take everything out and inspect it before they add their stuff. After it all checks out they will reinstall and fill it up and then you can change the fluid every 20 k or sooner if you like. They have the tool for you do do that with. He does go to some of the events around the country. He is very knowledgeable and very reasonable. Check them out.
sevin
May 2, 2026 06:11 AM
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
tr3y003
Oct 22, 2015 10:48 AM
ludedude
Aug 10, 2015 07:16 PM
