R50/53 R53 wouldn't start this morning
Old Dec 10, 2013 | 01:02 PM
Bleepmini's Avatar
Bleepmini
Well I went out to my 2003 Cooper S and when I put the key in all the lights came on but no start. I immediately pulled the battery and had it checked, it checked fine as it is only 2 months old. My FOB works with the doors and I was able to push start it and it stayed running for 20 mins. Does that rule out the EWS? I removed he heat shield and tested the started with a test light and it had constant power. I then checked the trigger and it also got its signal when the key was turned. Bad starter???
Old Dec 10, 2013 | 01:17 PM
GreekDrifter91's Avatar
GreekDrifter91
how cold was it in the morning? where are you located? cars have a hard time starting in very cold weather.
Old Dec 10, 2013 | 01:24 PM
Bleepmini's Avatar
Bleepmini
NY, I would say 30's. The battery was removed checked at a mechanics shop and then reinstalled.
Old Dec 10, 2013 | 01:40 PM
GreekDrifter91
ah nevermind then. it could be any number of things including just it being a one time problem. try some injector cleaner and or new plugs. how old are your plugs?
Old Dec 10, 2013 | 02:13 PM
Bleepmini's Avatar
Bleepmini
Well the fact that it has power at the starter and the trigger voltage was there upon turning the key, I would think that the fact that it wont turn over but everything else is working would point to a faulty starter right???
Old Dec 10, 2013 | 02:35 PM
GreekDrifter91
ahhh i must have missed that part, the starter wont turn the engine over? you may need a new starter, but try to clean up the contacts on the starter they may have corroded a bit. have you tried looking at what the voltage looks like when trying to crank?
iggi
18
Feb 9, 2026 01:00 AM
Melvinyip
Apr 17, 2020 09:28 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
Dsinkster
Aug 17, 2015 03:24 PM
kpl
Aug 11, 2015 04:52 AM
