R50/53 Cooling Fan Resistor Question
Old Oct 14, 2013 | 11:44 AM
afusco1222's Avatar
afusco1222
Is this a good upgrade if my resistor is on its way out?
http://www.rockauto.com/catalog/more...782&cc=1417171
Old Oct 14, 2013 | 11:54 AM
JAB 67's Avatar
JAB 67
I think there is a better one out there. Made by Dorman I believe.
Old Oct 14, 2013 | 11:55 AM
ZIPPY "S"'s Avatar
ZIPPY "S"
That resistor is what one would call a factory replacement.. That resistor is still prone to fail.. There are other aftermarket types that people have used instead.. Of course going with the aftermarket does require a bit of modification but nothing serious.. When my resistor went bad I just bypassed it...But the only down fall in doing that is the fan will run on high speed as the resistor is only used to run the fan at a lower speed.. But I will say it didn't bother me a bit.. Good luck!
Old Oct 14, 2013 | 12:01 PM
afusco1222's Avatar
afusco1222
I'm assuming this is the aftermarket solution.
http://www.detroittuned.com/dorman-gen-1-fan-relay-kit/
At 53 bucks, it's almost better just to get 2 factory units seeing that my mini has 155,000 miles on it. I don't think the fan resistor will be my biggest issue when the car hits 250,000 miles. How long are the stock units supposed to last?
Old Oct 14, 2013 | 12:02 PM
AlexQS's Avatar
AlexQS
I've been wondering "why" did they even have a low speed in the design? Is it just because of noise?
Old Oct 14, 2013 | 12:18 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
The way I understand it was to keep noise down... But honestly IMO that was a horrible design flaw... The resistor is so prone to failure and can do some costly damage when it fails..thats why I just bypassed it... not to mention it seems to keep my motor cooler which I feel is already running warmer then I like.. So by taking it out just keeps one less thing to go wrong.. Is the fan more noticeable now! "yes".. But its a sweet sound to my ears.. and its not any louder then any other car with a electric fan for cooling.. cheers!
Old Oct 14, 2013 | 12:31 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
I think these are what I would call an aftermarket factory type replacement.. In other words it is a bolt in replacement.. I have not personally installed any though.. Its good to see you have got some good miles on your MINI.. The factory type resistors that I have replaced all have been under 50k.. most around 20-30k miles.. So IMO that's a fast rate of failure.. But there are some better replacements out there.. I think if you search on here you will find better ones... But the ones you have posted will require less time for install.. good luck!
Old Oct 14, 2013 | 06:13 PM
minsanity's Avatar
minsanity
Dorman Kit:
http://www.ebay.com/itm/170969660469?redirect=mobile
Old Oct 14, 2013 | 06:40 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've sold several of these with good results
http://www.waymotorworks.com/radiato...0-r52-r53.html
Old Oct 14, 2013 | 08:40 PM
exocet's Avatar
exocet
Is there a guide out there for splicing in these resistors? I have the Dorman and have searched for a how-to but without success...
Old Oct 14, 2013 | 08:51 PM
AlexQS's Avatar
AlexQS
Is this what you're looking for, its a link I found on Detroit Tuned page where they sell the doorman kit:
https://store-zhkcqkob.mybigcommerce...0Fan%20Kit.pdf
Old Oct 14, 2013 | 08:57 PM
AlexQS's Avatar
AlexQS
Ps ,... There's additional info on the Detroit Tuned product description page, regarding if you have a 1 or 2 plug fan version.
Old Oct 14, 2013 | 11:33 PM
exocet's Avatar
exocet
Much obliged - that's the one. Got mine from Amazon so no instructions... and cutting wires makes me nervous
robbiedowns22
Aug 25, 2015 12:20 PM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
AZN Optics
Aug 16, 2015 11:52 PM
ki7hy
Aug 12, 2015 07:07 PM
