R50/53 Automatic r53 radiators? replacements?
Old Oct 13, 2013 | 09:45 AM
WizardEyes's Avatar
WizardEyes
I'm looking for aftermarket replacement of my radiator in my automatic r53, but any I look at online says manual only. What's the big difference???? Anyone know where I can get a cheap replacement that fits the r53 auto?
Old Oct 13, 2013 | 12:32 PM
AlexQS's Avatar
AlexQS
Not sure what year you have, and I know that the hoses are different on an automatic than a hoses on a manual trans.
I always thought the radiators were the same on either one.
I looked it up on realoem.com. They show hoses for automatic, hoses for manual
Then -On the page that shows 'radiator' there is no distinction of the kind of transmission, instead it had the words Canada International.
I'd call the guy at ECS, he's super good at part numbers and detail info like that.
They have options including: an Genuine MINI brand, an upgrade all aluminum, and two aftermarket (less expensive) alternatives. None of them specify a particular transmission type.
Edit: here's a link http://www.ecstuning.com/Mini-2005-C...ling/Radiator/
Old Oct 13, 2013 | 01:05 PM
ZippyNH's Avatar
ZippyNH
On many cars, you install the same radiator if you do aftermarket....
You just do not connect the tranny cooler loop at the bottom with a stick...
Not sure if the rad is different..look up the OEM part # on realoem.com?
Old Oct 13, 2013 | 11:02 PM
IDOXLR8's Avatar
IDOXLR8
I have to agree with this post, I have seen the prices go from $50.00-over $300.00! What gives here? What is the best radiator for the buck with no mods for installation? I have a base 2003 MINI automatic, thanks, AL.
Old Oct 14, 2013 | 02:31 PM
AlexQS's Avatar
AlexQS
Hi AL, -Sorry I don't have more advice, I have an 05 "S" model, with manual transmission, and I don't know enough about automatics to be helpful.
Best radiator for the buck,... Well I'm going with the all aluminum Mishimoto. I'm sure it's more than I need, but I like the lifetime warranty. They'll replace it even if the damage is caused by hitting a tree! Now that's a warranty!
Vendors on here like WMW, ECStuning, Pelican Parts and others know MINI's as well as anyone. Call one of them; they'll likely ask you of your intended use of the car, and hook you up with your best option for a direct fit replacement.
Old Oct 14, 2013 | 05:42 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The Automatic and manual have the same radiators. We carry the original: http://www.waymotorworks.com/radiator-for-r52-r53.html
And the Mishimoto:
http://www.waymotorworks.com/mishimoto-radiator.html
Old Oct 14, 2013 | 11:23 PM
IDOXLR8's Avatar
IDOXLR8
MINI Radiator
And the Mishimoto:
You made my point! Your is $300.00, that's about the price at the MINI dealer! What brand name is yours and what is your part# ? Thanks for your follow up, AL.
Old Oct 15, 2013 | 06:00 AM
Wizards and Alex - Think you are talking about the R53 / R52 Cooper S version. Auto and manual.
Aluminum Radiator Part # 17117570489
http://www.ecstuning.com/Search/SiteSearch/17117570489/
While I think IDOXLR8 " I have a base 2003 MINI automatic, thanks, AL." which needs the R50 / R52 (Non - S ) version. Auto and Manual.
Aluminum Radiator Part # 17117570821
http://www.ecstuning.com/Search/SiteSearch/17117570821/
Thanks , just wanted to make sure things are not mixed up. Let me know IDOXLR8 that's what you meant.
Old Oct 15, 2013 | 10:58 AM
AlexQS's Avatar
AlexQS
Details are important! Good catch ECS.
So there's no difference between auto and manual trans radiators.
But the r50 radiator is different than the r53 radiator. Good to know.
Old Oct 15, 2013 | 11:06 AM
You are welcome. Cooper vs Cooper S on Gen 1 MINIs.
blackie
Jan 18, 2017 09:56 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Zettinger
Aug 25, 2015 04:04 PM
BernieCoop
12
Aug 12, 2015 07:45 AM
