R50/53 Stoker's Rebuild Thread
Old Dec 15, 2013 | 04:38 PM
  #76
Raven Mocker's Avatar
Raven Mocker
Originally Posted by Stoker
The Work Continues..
Sea-Foam made it easy to clean the pistons..
Once that was sorted.. in went the studs, the chain tensioner and guides..
then the head and adjustable sprocket..
I use sea foam at times. Try BP Blaster next time as it removes carbon build better. Just look at it as Sea Foams evil twin.
Old Dec 15, 2013 | 04:48 PM
  #77
Stoker's Avatar
Stoker
Originally Posted by Raven Mocker
Sea Foams Evil Twin.
Good name for A Band!!
Old Dec 15, 2013 | 04:53 PM
  #78
Raven Mocker
LOL!
I just know between the two brands the PB Blaster broke down and removed carbon build up on 2 stroke engines better then the Sea Foam. Same experience when cleaning diesel intakes manifolds.
Old Dec 15, 2013 | 04:55 PM
  #79
Stoker's Avatar
Stoker
Clutch Is In!!
Stage 2 Spec Clutch w/Phantom grip LSD….. Pic is kinda dark, it's the box looking thing in the middle with the red springs.. Tap.. tap, tap.. installed...
Attached Thumbnails Stoker's Rebuild Thread-spec-large.jpg   Stoker's Rebuild Thread-phantom.jpg
Old Dec 15, 2013 | 05:02 PM
  #80
Stoker's Avatar
Stoker
LOL!
Yeah i used PB, Sea Foam, and break cleaner to clean the flange between the clutch and the tranny (no gasket).. made life very easy.. the crud just "wiped" off..
Old Dec 15, 2013 | 05:12 PM
  #81
Stoker's Avatar
Stoker
Originally Posted by Saltysalt
6 deg F outside right now
Thats way to cold to be mucking around with cars…
Old Dec 15, 2013 | 05:52 PM
  #82
Stoker's Avatar
Stoker
Originally Posted by DICKS GARAGE R53
We may be small (pun intended) but were a cut thought bunch!
You should try running a music composition forum!! Every opinion is subjective. There is "no" frame of reference, no quantifiable data.. I closed it down.. It was a battle royal from the get go.. all things considered, you guys are relatively polite ")
Old Dec 15, 2013 | 06:03 PM
  #83
Stoker's Avatar
Stoker
I have to say, there's nothing nicer, than a clean engine!! after you've finished, the world just seem's to make sense...
Old Dec 15, 2013 | 07:03 PM
  #84
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
So you are up and running?
Old Dec 15, 2013 | 07:13 PM
  #85
Stoker's Avatar
Stoker
I Wish.. we tore up the gear change cable bushing rubber (tranny end) it was rotten, needed replacing anyway. so, i ordered two new cables..Wednesday..
all we have to do is re-assemble, put those on, flash it for 550's.. Bob's your uncle!!
Old Dec 15, 2013 | 07:40 PM
  #86
DICKS GARAGE R53
Well I added you to the Sprintex Owners List anyhow... You are #18! (I know there has got to be more than that out there, but if they dont come foreword I can not add them.) Dont forget to post some #'s up there...
Old Dec 15, 2013 | 08:17 PM
  #87
Stoker's Avatar
Stoker
Your the man!! I'll put those number's on the car somewhere ") Steve Tech (Custom Mini Shop) Can Be Number 19, he has his Sprintex sitting in the box ready to go.. (He never has time to work on his Mini)
Old Dec 15, 2013 | 08:41 PM
  #88
DICKS GARAGE R53
No the 18 doesnt go on your car unless you want it, but if you could add some dyno numbers to the list thread, that would be great.
Old Dec 15, 2013 | 09:17 PM
  #89
Stoker's Avatar
Stoker
18 will look great under one of the scuttles. Depending on whether i can find the guy in fresno who has a dyno… he moves around. eventually, i'll throw up some numbers..
Old Dec 16, 2013 | 09:11 AM
  #90
MiNiSandpirate's Avatar
MiNiSandpirate
the reason why some of us look at this stuff and ask wtf, is because alot of us have been around long enough to see this scenario played out time after time after time and the results are always the same....dump tons on money into this that and the other...but cheap out on a critical part or system, then it takes massive dump and you are left a expensive paperweight...if i was going to open a transmission to put a clutch in there for a modded setup i would just spend the money and do it right
Old Dec 17, 2013 | 12:20 PM
  #91
Stoker's Avatar
Stoker
The euro parcel shelf
There is no room in a mini to put stuff, Things like your wallet, house keys, the usual everyday odd's and end's you need. But, are uncomfortable in your pockets while driving.. last week, buddy took me for a spin in his R53, as i was perusing the interior of his mini, i saw he had a shelf under the steering column. "The euro parcel shelf" he told me "Really hard to find" he said. Turns out they're not. Out Motoring "Had" 17 in stock, now, i have one of those..And a place to put all my junk. besides, the center console bucket which isn't conducive for DD. Comes with the switch cover, mounting screws and a bottom liner.
Old Dec 17, 2013 | 02:59 PM
  #92
DICKS GARAGE R53
Whats with the T-Rex???
Old Dec 17, 2013 | 04:44 PM
  #93
Stoker's Avatar
Stoker
It's funny, until you mentioned it. I hadn't noticed it. now, thats all i can see ")
sorry..
Old Dec 17, 2013 | 09:51 PM
  #94
SpiderKnight's Avatar
SpiderKnight
I thought it was to give us a scale for the parcel shelf.
Old Dec 17, 2013 | 10:07 PM
  #95
Stoker's Avatar
Stoker
OMG!! It's perfectly placed.. I can't delete the Pic :-(
Old Dec 20, 2013 | 09:08 AM
  #96
Stoker's Avatar
Stoker
I'll be done today
Where I got to last night… IM is on, Injectors are in, subframe today, radiator and the bumper carrier, fender and wheel wells.. I'm driving again..
it's been two weeks since i've driven my car..can't wait..
Old Dec 20, 2013 | 04:51 PM
  #97
Stoker's Avatar
Stoker
Well not quite as much done as i expected today, i helped put another clutch in (Third clutch in two weeks. Now i know how to change the clutch on a 1st gen mini in my sleep )
Anyway tomorrow, all i have to do is put the bumper and intercooler on, flash it for the 550's..
Swapping out the gear change cables made a huge difference to the "feel" of the tranny!! the old ones were full of crud...
Old Dec 21, 2013 | 03:41 PM
  #98
Stoker's Avatar
Stoker
The MINI is home and running like a top!!
Big thanks to Steve Tech from Custom MINI Shop, Fresno.
Old Jan 2, 2014 | 05:04 PM
  #99
Stoker's Avatar
Stoker
So anyway, the clutch "break in period" is driving me nutz.. i had a lapse last night, I was stunned. Call me a Happy camper!!
I edited my first post for the mods..
Old Jan 9, 2014 | 03:55 PM
  #100
Stoker's Avatar
Stoker
350 miles nearly there…
Did the wideband couple of days ago, just put in the fancy chrome bits..
The engine light is from the "P1477" code. I have a vacuum leak somewhere..
got to take the intercooler off and have a look.. The rubber grommets for the breather tubes, on the SC air tube to the TB, aren't as tight as they should be, meaning it's a slightly loose fit..
