R50/53 Need help: VIN sticker placement on doorjamb
Old Sep 6, 2013 | 10:23 AM
Marquette MINI's Avatar
Marquette MINI
Several months ago I had both my rear quarter panels replaced under warranty on my 2006 MCS for rust damage underneath the taillights. In the process, the body shop failed to transfer or replace the VIN and tire pressure stickers, which I noticed about a month after. I went back and forth with the dealer for a while until they finally agreed to have it reprinted.
The service advisor just recently sent me the sticker in the mail for me to apply myself. However, I don't remember exactly where on the doorjamb it was located. I'd like to have it as close to original as possible. (I know, I'm a bit ****.) Can someone take a picture of their VIN label that shows where it is placed on the doorjamb?
I also wanted to get the tire pressure sticker replaced, but the service advisor tells me without the original there is no way to know which sticker was on there - supposedly there are several different ones. If he had the part number of the original he could get it but too late now...
Old Sep 7, 2013 | 07:16 PM
pedalquickly's Avatar
pedalquickly
I started looking for my VIN a few month ago after purchasing an 06 and the only spot that I could find it was under the hood. It is printed big and has a clear sticker protecting it. I don't have any stickers in the door jambs..
Old Sep 7, 2013 | 07:32 PM
kramseib's Avatar
kramseib
Being concerned about placement will not bring you any more value on a resale. But, just as east to take a look at ANY other vehicle. I don't think MINI would be any different than other manufacturers.
Old Sep 8, 2013 | 10:35 AM
Marquette MINI
Agreed, but I'm not asking this question for the sake of resale. I am just wondering if the sticker was closer to the door strike plate? Or closer to the bottom sill? I seem to recall that the tire pressure sticker was ABOVE the VIN sticker, which means that it might have been closer to the bottom of the door jamb.
FWIW, my other car is an Audi and the door VIN sticker is actually higher up on the door jamb, between the strike plate and the outside edge of the door jamb. So placement does vary by manufacturer.
Was just hoping that someone would have been kind enough to post a picture of his or her VIN sticker here so I could see exactly where it goes. Guess I'll just keep an eye out for other MINI drivers when I'm out and about and ask if I could look at theirs.
Old Sep 8, 2013 | 10:37 AM
Marquette MINI
Then your car has most likely had some body work done. It came from the factory with a VIN label and a tire pressure sticker on the driver side door jamb.
Old Sep 8, 2013 | 02:39 PM
AlexQS's Avatar
AlexQS
Here you go:
The VIN sticker is about two fingers below the door latch strike plate.
The edge of the tire sticker is right about where the curve in the door jam is.
There are two other little stickers, and they're about a key length from where the black plastic ends....
See photos.
Old Sep 8, 2013 | 06:49 PM
Marquette MINI
Perfect! Exactly what I needed to know. Thanks!
Old Sep 9, 2013 | 10:22 PM
FredoinSF's Avatar
FredoinSF
Reading the original post helps
Peking Duck
Jan 19, 2021 03:17 AM
dgamblin
Jan 2, 2021 02:57 PM
RobbyD
Jan 29, 2019 01:22 PM
vulkandino
Oct 31, 2015 08:29 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
