R50/53 What are these lights?
Old Jul 15, 2013 | 06:01 PM
CarFreak427's Avatar
CarFreak427
I've never seen them come on. Aren't they supposed to be on with the daytime running lights?
Old Jul 15, 2013 | 06:33 PM
PFCflanders's Avatar
PFCflanders
The fogs?
Old Jul 15, 2013 | 06:39 PM
CarFreak427
No, the lights that take up a small portion of the turn signal housing. Not the orange part of the circle, but the little bit to the left in the pic.
Old Jul 15, 2013 | 06:43 PM
PFCflanders
I guess you could call those running lights, they've always worked perfectly on mine. Check the bulbs, they should come on every time you turn on the headlights or just one "click" up on the headlight/turn signal stalk.
Old Jul 15, 2013 | 06:48 PM
baznight's Avatar
baznight
Front parking lights. They use a small "peanut" bulb. They should be on with the lights on.
Old Jul 15, 2013 | 06:50 PM
CarFreak427
Good to know their technical name. Now Im thinking both of the bulbs are just coincidentally out. The previous owner also had the running lights that are in the high beam housing programmed to be on with the stock in the off position so I thought they should be on. I'll check when I get home in about a month. I'm hoping to put some halos in that spot as well. Hopefully the lights work and will come on with the headlights. Or something.
Any opinion on these? http://www.autoall.com/mini-fog-lights.htm
Old Jul 15, 2013 | 07:35 PM
rkw's Avatar
rkw
Originally Posted by CarFreak427
I have tried them and returned them (not from this vendor, but one of the same design). Very dim, and uneven light around the ring.
Old Jul 15, 2013 | 08:24 PM
CarFreak427
Any recommendations on something similar?
Old Jul 16, 2013 | 07:45 AM
Those are the front position / turn signal assemblies. Here is what they look like from the front and rear if you are looking. The housing tend to get cracked from the rocks and road debris.
#1 in diagram
Turn Signal Assembly - Front Left part number 63137165861
http://www.ecstuning.com/Search/SiteSearch/63137165861/
Turn Signal Assembly - Front Right part number 6313716586
http://www.ecstuning.com/Search/SiteSearch/63137165862/
The stock bulbs are #5 5w Part number 63217160797
http://www.ecstuning.com/Search/SiteSearch/63217160797/ES174569/
#4 The regular bulb for the flashing turn is 63217160791
http://www.ecstuning.com/Search/SiteSearch/63217160791/ES174564/
Old Jul 16, 2013 | 08:18 AM
cooperScaleb05's Avatar
cooperScaleb05
What's the best way of changing the bulbs?
Old Jul 16, 2013 | 08:25 AM
You can reach it this way.
From the top cavity right next to the hood latch with hood open on either side, Its kind of tight but your fingers can reach in there and twist them out or try to reach it with a tool. Unplugging the harness to each one before makes it easier to remove.
Here a good how to.
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
