R50/53 How many belts 06 cooper s
Old Jul 4, 2013 | 06:30 PM
pedalquickly's Avatar
pedalquickly
I went to two different auto parts stores looking for the sepertine belt and both said I had two belts? I can only see the longer sepertine. Is there another shorter belt? If not why are the parts stores confused.
Old Jul 4, 2013 | 07:09 PM
Da_Ghost's Avatar
Da_Ghost
There's only one! No idea why they're saying there's two!
Old Jul 4, 2013 | 07:39 PM
AlexQS's Avatar
AlexQS
^^ + 1. There's only 1 belt.
Old Jul 4, 2013 | 08:09 PM
ZippyNH's Avatar
ZippyNH
Yup....one belt...get a new parts place.....
Internally there is a timing chain...so no belt there either...
Old Jul 5, 2013 | 07:50 AM
+1 just one belt here is a diagram.
There is stock belt size for the Cooper S Part 11287520199
http://www.ecstuning.com/Search/SiteSearch/11287520199/
There is a Stock belt size for the John Cooper Works. Part 11287545120
http://www.ecstuning.com/Search/SiteSearch/11287545120/
Old Jul 5, 2013 | 07:56 AM
pedalquickly
Thanks. .is there a gates crossover number. I bought one from one of the stores that said I needed two and they gave me a gates.
Old Jul 5, 2013 | 08:03 AM
ZippyNH's Avatar
ZippyNH
Do you have a stock sc pulley or a reduced One...aka 15% or 17% ...or even the JCW?
All need a different length belt...
Brand does not really matter....any 6 rib belt of the right length works.... IMO the parts store s sells belts that is longer than needed to make it easy to put on...but they will slip on the sc...and make noise...loose power..and maybe fail.
Post if you are stock or not....
Old Jul 5, 2013 | 09:16 AM
pedalquickly
As far as I know im stock. The car has a john cooper works logo on the breather box but I as well as the prevoius owner didn't know what is special about the car. It is the checkmate edition if that means anything.
Old Jul 5, 2013 | 06:42 PM
ZippyNH's Avatar
ZippyNH
I'm drawing a blank on the us sizing for a std belt....stock is 1388 mm....us sizing uses a different length system....for example I use a 535 or can use a 532 length belt with a -17% reduction....stock might be a 547....or one step shorter....a quick search or another poster should chime in....
Old Jul 8, 2013 | 11:34 AM
Could be a checkmate edition with just a JCW airbox. Its a popular upgrade to just due the JCW airbox.
Here is the Checkmate edition that was for sale. No stock JCW tuning kit.
https://www.northamericanmotoring.co...checkmate.html
If its a JCW Tuning Kit ( add on ) in edition to the Checkmate , it will have a plaque on the valve cover that will say JCW tuning Kit and then a serial number.
JCW airbox: #1 in diagram .
John Cooper Works Intake Kit part number 13720391513
http://www.ecstuning.com/Search/SiteSearch/13720391513/
We also carry the stock JCW Airbox Filter and the Pipercross version.
JCW Kit Air Filter Part number 13717558382
http://www.ecstuning.com/Search/SiteSearch/13717558382/
Performance Foam Air Filter - JCW part number PX1875
http://www.ecstuning.com/Search/SiteSearch/13717558382/ES2623170/
Belt Size :
6PK X 1388 11287520199 Stock Cooper S
6PK X 1374 11287545120 JCW Belt
BTW the checkmate was a very cool option back in 2006.
Here is some more info.
If that helps.
Old Jul 8, 2013 | 05:21 PM
pedalquickly
Hey Thanks for all the helpful links. My airbox looks like the one on the diagram except it has the "John Cooper Works" emblem on it. What does all of that do for you that stock one don't?
Attached Thumbnails How many belts 06 cooper s-0b7ccf0c5bcb345b392f7634e0b233f0_zpsa6f8ad9f.jpg
Old Jul 8, 2013 | 07:35 PM
ZippyNH's Avatar
ZippyNH
It is the factory CAI (cold air intake)....
a bit of HP....2-3 HP...but a bit of sound....there is a flap that opens at higher rpm's...some folks remove the flap to get more sound all the time....
and the the "JCW" sticker....some folks like that stuff....
Old Jul 9, 2013 | 04:02 AM
pedalquickly
I don't know if it's factory or not as it was already in there when I got the car a couple of weeks ago. It think it looks factory...
iamcamkeenan
Aug 10, 2015 03:31 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
