R50/53 Public Service Announcement - Check Your Oil tody and a poll
Old Apr 10, 2013 | 05:27 AM
Kahnfucious's Avatar
Kahnfucious
Hey guys,
Just reminding everyone to check their oil today -- I check about every two weeks and have been finding that I lose about 1/2 quart every 2,500 miles. I think I have a little bit of weeping at the oil pan (however this gasket was changed professionally about 10,000 miles ago).
Just curious how much are you guys adding oil to your cars?
2003 R53 with 80,000 miles on it.
We drove this car back from California after buying it with no issues -- but just in case I roll with 3 quarts of oil in the boot.
Old Apr 13, 2013 | 02:04 PM
Kahnfucious
No one has to add any oil ever?
Old Apr 13, 2013 | 02:59 PM
niquemarshall's Avatar
niquemarshall
I haven't had to add oil to my car since I changed my oil cooler gasket.
2004 with 106,000 miles
Old Apr 13, 2013 | 03:10 PM
leaf_fan_1988's Avatar
leaf_fan_1988
If you look under my car, you can tell oil is leaking from somewhere, but the level never drops on my dipstick, and I change my oil after 8,000 KM.
'05 R50 168k KM
Only replaced the valve cover seal to keep my engine looking prettier, and my plugs drier.
Old Apr 13, 2013 | 03:22 PM
Kahnfucious
Happen to have a link to the procedure for changing this out?
Old Apr 13, 2013 | 04:00 PM
kedwards's Avatar
kedwards
I probably need 1/2 quart every 3 fill-ups. I don't like to let it get low.
Keith. who has driven a lot worse...
Old Apr 13, 2013 | 05:07 PM
bmwr606's Avatar
bmwr606
i check my oil level every day
when i change oil, i only add 4 qts which puts the oil level about at 1/2 and it stays there until the next change at 4,000 mile intervals
scott
Old Apr 13, 2013 | 06:37 PM
Kahnfucious
Hmm...pretty sure the mini calls for 4.7 qts so kind of surprised you only put in 4...
I guess on a 10 year old car 1 quart of loss every oil change isn't so bad.
Old Apr 13, 2013 | 06:42 PM
bmwr606's Avatar
bmwr606
N18s get 4.4 qts to full, i use 4 qts to about half
scott
Old Apr 13, 2013 | 09:48 PM
JTOR53's Avatar
JTOR53
I will add about 1/4 to 1/2 quart every 3500 miles before oil changes.No leaks that i can see... 85k miles 04' R53..
Old Apr 14, 2013 | 12:42 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
All seeping gaskets and O rings were addressed at 80K miles.
Since then I also change the PCV Valve every 30K miles.
Oil changed every 5K miles.
Now at 174,000 miles and no consumption, zero, nada, goose egg.
Old Apr 14, 2013 | 12:46 AM
-=gRaY rAvEn=-
Moderator
scott
Looks like you have the Peugeot Engine.......this is a 1st Gen thread.
Old Apr 14, 2013 | 05:57 AM
Kahnfucious
Thanks gray raven. I guess until I move out of the NYC and have a place to take apart the car I'll just keep adding oil every 2-3000 miles. I change oil at 5k usually.
Is there a list of all the gaskets and O rings that you took care of?
Old Apr 14, 2013 | 06:24 AM
bmwr606's Avatar
bmwr606
i still think my point about letting the engine find it's own level to maintain the oil is valid
i own 4 vehicles and an airplane
everyone of them will consume oil if the oil level is put to the full mark and none of them consume oil if i run the oil level at some point below full
the most extreme is my 1997 gmc sonoma 4.3 v6 ... at 290,000 miles it still goes oil change to oil change (5,000 miles) without adding oil if i run the level at 1/8" above the "add" line ... any higher than that gets quickly consumed
scott
Old Apr 14, 2013 | 06:38 AM
Fly'n Brick's Avatar
Fly'n Brick
My oil change guy puts in as much as he takes out every 5K, right now it has 67.5K logged on the fun meter. I check it at least weekly and almost always while waiting at the pump. Now, I'm gonna knuckle that wooden desk top and hope to he!! the gremlins weren't paying attention.
Colt45Magnus
Jul 14, 2019 06:18 PM
minicoclub
Aug 25, 2015 09:07 AM
AoxoMoxoA
Aug 21, 2015 09:15 AM
kwijmbo
Aug 5, 2015 09:00 PM
